Im ashamed to say this but ive been chasing this problem for a month now and i still cant find the problem.
i replaced my rear brake shoes ,wheel cylinders , the whole rear drum springs and the flexible brake lines.
my brakes only lock up when i brake hard , and when they do i have to bleed out the nipple to release the pressure from the whleel cylinder.
1987 ford f150 5.0 v8 Manual
Reason: Important information:1987 ford f150 5.0 v8 manual
This sounds like an issue with the offending wheel cylinder if it only happens to just one cylinder, if both rear wheels then possibly a restriction between the master cylinder and wheel cylinders.
If the wheel(s) lock up does it seem to release after it sits a while?
