76 f250 Bendix control valve fitting size
Old Jan 22, 2023 | 08:50 PM
76bigblue's Avatar
76bigblue
Trailering
When replacing the power steering control valve (bendix) I broke off the small fitting in the old valve for the line closest to the cab (back left if you look at the valve from the front of the truck). Does anyone know what size that little adapter fitting is? I found a part number for all 3 but they are out of stock. I tried to search and found d3tz-3c656-a for all 3, but I can’t find it anywhere. Would a new line come with this fitting?
Old Jan 23, 2023 | 09:48 AM
Mark8man's Avatar
Mark8man
So its the one circled? going into the valve is 1/4" NPT but I am not sure of the flare angle/size where line connects. Try taking the pieces to a NAPA or a place that makes hydraulic hoses and They may be able to match it up or at least figure out the fitting description.
Old Jan 23, 2023 | 03:38 PM
76bigblue's Avatar
76bigblue
Trailering
Yea that’s the part. Broke it in half. I ordered new hoses for the left and right turn hoses. The ones I had look original and were probably going to leak any day. If it’s 1/4 npt into the valve, the new hose is supposed to have 5/16 female sae fitting per the website. I don’t know much about these connectors, but would that mean I need a SAE 45 Degree Flare Adapter Union, 5/16" Flare Male to 1/4" NPT Male.
example fitting
User 32921
Sep 26, 2021 12:47 PM
kegger66
May 20, 2017 10:13 PM
alchemist1
Jun 12, 2013 06:10 PM
alchemist1
19
Jan 17, 2013 10:24 AM
56efffie
Oct 24, 2007 10:05 AM
