Combination valve
Old Oct 23, 2007 | 10:48 AM
56efffie's Avatar
56efffie
Combination valve
Hey guys,
I pretty much have the brakes plumbed except for the point where the rear line attaches to the combination valve directly under the master cylinder. I was surprised to find that the the stock brake line fitting coming from the rear to the combo valve was a size too small. Is this a common problem and what size do you think I need to adapt my stock line to the valve?
Thanks,
Old Oct 23, 2007 | 11:06 AM
Truxx1956's Avatar
Truxx1956
Hey man, you can get an adaptor to adapt your current line to the prop valve.I've done it alot, you can get them from the twilight zone(auto zone) or other parts houses. Make sure you get one with the proper threads and not one that's close enough. Sometimes they feel like the correc threads and dont have a "seat" in the bottom of them to seal against the fitting. If I had the part number handy I'd give it to ya for the most common one I use.
Old Oct 23, 2007 | 11:20 AM
56efffie's Avatar
56efffie
Thanks for the reply. I was not aware on the different thread sizes, good to know. Now where in the heck did I put those cookies?
Old Oct 23, 2007 | 05:42 PM
AXracer's Avatar
AXracer
late model MC and prop valves use 2 different sized fittings so some dumba** doesn't hook em up backwards.
Old Oct 24, 2007 | 10:05 AM
56efffie's Avatar
56efffie
Thanks AX, I guess they were successful because if they were the same I may have just been that dumba** you were referring to. J/K
Grendelx
Sep 10, 2012 10:08 AM
jerryst
Mar 25, 2012 04:52 PM
monte97z
13
Feb 7, 2012 12:52 PM
jthomps3
Mar 6, 2002 10:08 PM
MarkP
Aerostar
Jan 27, 2001 06:34 PM
