1978 - 1996 Big Bronco
BRONCO VACUUM HOSES
Old Jan 22, 2023 | 01:02 PM
CHUCHI70's Avatar
CHUCHI70
4th Gear
BRONCO VACUUM HOSES
Dose any body know we’re this hoses or the 3 connections go or any pics would help
I would greatly appreciate it it’s driving me crazy 😜
Old Jan 25, 2023 | 12:15 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I bet w/s squirter. Looks I got in the late model Bronco dept by mistake. Woops.
Old Jan 25, 2023 | 06:25 AM
manicmechanic007's Avatar
manicmechanic007
I am assuming that is your vacuum tee (tree) and those are indeed vacuum lines
Basically
1 will go inside for the HVAC (goes to the vacuum mode switch)
1 should go to a vacuum canister on the fender apron somewhere
1 goes to the intake manifold for supply vacuum
You need a correct VECI for your truck which was once on the radiator support, to be absolutely sure
Good luck
Old Jan 25, 2023 | 10:08 AM
CHUCHI70's Avatar
CHUCHI70
4th Gear
Vacuum hoses
Thank you so much I appreciate the information I’ll check it out & I’ll let you know 🤔 thanks again
Old Jan 25, 2023 | 10:12 AM
CHUCHI70's Avatar
CHUCHI70
4th Gear
Also the one plug on the right was connected to the back of the manifold
Old Jan 26, 2023 | 11:26 AM
torq'ta 5 8's Avatar
torq'ta 5 8
what year, and motor
Old Feb 4, 2023 | 02:35 PM
CHUCHI70's Avatar
CHUCHI70
4th Gear
Vacuum hoses
Hey buddy it’s a 1988 5.8 Edie Bower
Old Feb 4, 2023 | 03:19 PM
torq'ta 5 8
this link has pics-->Replace Plastic Vacuum Hoses with Rubber - Ford Bronco Forum
damnedin82
Feb 4, 2022 06:28 AM
kevinv10
Aug 30, 2020 05:07 PM
96F150-4.9
Jan 12, 2019 05:03 PM
blackjack33
Jul 26, 2016 08:27 PM
bsr2002
Aerostar
May 23, 2010 05:00 PM
