Manual conversion
Old Jan 21, 2023 | 11:48 PM
Rusforde350's Avatar
Rusforde350
3rd Gear
Manual conversion
Hello I’m Simon. I have a 2001 e350 sd 5.4l 2v truck. I’ve done a manual conversion. Truck ran great at first as time went on, within a six months period truck begin losing power when I accelerate. Transmission wiring harness is gone, which wiring pins do I need to jump to have the ability to start the car with the key?.(push button for right now) which wires do I need to jump to complete the can-bus system? The truck has no catalytic converter’s and revs up if I slowly give it gas. But if I floor the accelerator, it hesitates, misfires and cuts off. Help please I can’t seem to find any wiring diagrams on the Internet. I am a mechanical engineering, so I know it can be done just a matter of a few resistors in a few jumps. I just want the engine to run as if it’s in neutral I will delete any and all unnecessary systems. If it cannot be done with the factory ECM I am thinking about switching to a standalone MAP ecm any help would be appreciated
Old Jan 22, 2023 | 08:05 PM
econo93's Avatar
econo93
So the trans it out of a pickup? And you have an ECM from a pickup?
Old Jan 22, 2023 | 10:16 PM
Rusforde350
3rd Gear
No, I bought the truck with a seized engine and no transmission so I thought I would put a ZF5 speed that I bought from the Internet never had a manual PCM if all else fails, I was thinking about running my own wiring harness for the lights and putting everything else on a standalone ECU the engine is not it’s own either it is a second generation lightning truck engine built for 28 pounds of positive displacement
Old Jan 29, 2023 | 05:06 AM
FinnishStroker's Avatar
FinnishStroker
Welcome to the FTE!
Can't help with your problem but can you post pics from clutch and gear shifter?
I have been planning a manual swap, If my 4r100 ever explodes.
Where did you get the clutch bits and pieces?
I know that Econoline has come with an manual paired to 300cid six.
Old Jan 30, 2023 | 12:11 AM
maples01's Avatar
maples01
Check fuel pressure, your pump could be failing, if it sat a long time, the fuel in the tank could be bad, I had one sit over 6 months, had trash and rust in the tank.
Old Oct 5, 2023 | 10:17 PM
Rusforde350
3rd Gear
Manual convt
Originally Posted by FinnishStroker
Welcome to the FTE!
I know that Econoline has come with a manual paired to 300cid six.
clutch came from a deisel f250
clutch fork had to be shortened by me.
Must use .025 spacer for fly wheel clearance.
Pedal assembly was made by me from a spare brake pedal laying around with a double lever power multiplier 7 in of pedal travel to 1 3/8 of master cylinder travel.
I’m tired of messing with it I’m goin full stand-alone ecu.
it will also allow me to get rid of a bunch of unnecessary electronics under the hood.
hillbilly ford
Oct 30, 2021 10:41 PM
docweathers
Sep 22, 2012 12:37 AM
