Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Air brake compressor ID
Old Jan 19, 2023 | 01:50 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
Anyone have a Ford L/F series with a 3208 cat with air brakes? I need a part number for the belt-drive compressor.
Anyone that can help with identifying the right compressor would be a big help!
Old Jan 19, 2023 | 06:26 PM
Destroked 450's Avatar
Destroked 450
Ford used Bendix brand compressors in most of their apps back then
A heavy duty tractor parts supplier should be able to match up your pump
The Bendix Tru Flow 501 was a popular compressor for that engine
Whats wrong with it
Old Jan 19, 2023 | 08:19 PM
fivestarmmd's Avatar
fivestarmmd
Intake reeds stuck? D2 governor bad? Seen both symptoms after setting awhile.
Old Jan 19, 2023 | 10:03 PM
Destroked 450
Is it not building full pressure or cycling up and down
Not building pressure is usually the governor
Replace the governor
Cycling is usually the o-rings on the unloader valves
you can access them thru the air intake port
jhruzek
May 19, 2015 04:39 PM
cbzdel
May 23, 2012 08:21 AM
F3fitty
All Other Items for Sale
Aug 4, 2011 10:10 PM
knightshield
Garage & Workshop
18
Mar 7, 2004 03:24 AM
