Towing capacity
Old Jan 18, 2023 | 08:47 PM
Anonymous12's Avatar
Anonymous12
Towing capacity
For a 1988 f-150 single cab long bed xlt lariat what is the bumper pull towing capacity? It has a 3800 gawr in the rear. It has a 8.8 rear end I think. It has a 302 v8, with a AOD 4 speed automatic.
what is the 5th wheel/gooseneck one also if it has one?
Old Jan 18, 2023 | 09:10 PM
85e150's Avatar
85e150
Closest I could come:
https://www.ford-trucks.com/forums/1...302-8-cyl.html
3500 lbs. That AOD is a weak sister, and a 5th wheel/gooseneck is out of the question with that limit.
Old Jan 18, 2023 | 09:11 PM
cannothinkofaname's Avatar
cannothinkofaname
This thread looks similar to your question.
https://www.ford-trucks.com/forums/1...questions.html
Old Jan 18, 2023 | 10:39 PM
Anonymous12
I saw that thread, but I figured it would be different being a 96 and I know newer trucks trim level affects towing so I just posted a new thread, while I’m asking this does anyone know payload?
Old Jan 18, 2023 | 11:05 PM
Prototypemech's Avatar
Prototypemech
Long answer: Payload is determined by subtracting the trucks empty weight (with driver and full fuel tanks) from it's gross vehicle weight rating.
Your door tag will specify what your GVWR is.
You empty-weight will very depending on your trucks configuration (2wd vs 4wd, long bed vs short bed, auto vs manual). A certified truck scale will charge you ~$12 to put your truck on their scales and get an real empty weight.
Short answer: About 1400 lbs.
Old Jan 18, 2023 | 11:18 PM
Anonymous12
All right eventually I’ll get it weighed and everything. The reason I posted this asking is because my door sticker displays GAWR not GVWR.
Cutter21
All Things Towing
May 11, 2022 05:56 PM
wozxxx86
1978 - 1996 Big Bronco
Nov 13, 2004 11:45 AM
Deansinger
Sep 22, 2004 01:19 PM
transpo1
Feb 8, 2004 09:02 PM
altastars
Jul 31, 2003 12:10 PM
