Are you looking for the maximum GCWR? If so you need to provide more specific information. Is your truck a dually, what transmission, what configuration is the cab/bed?
Click on the Towing Capacities link on the left side of the page...
As you can see, towing capacity is not an easy number to determine. You have to know things like rear end gear ratio, and what options (read: extra weight) which you have on your truck. This chart is a good start.
According to the literature I have "FMC 2002 RV and Trailer Towing Guide" tow behind capacity is 12,500 pounds, 5th wheel capacity is 13,700 reg cab, 13,400 SC and 13,100 crew.
Edmo
That is a great link. I have a 2003 spec sheet and was considering scanning it into the thread. That site has a lot of great data, maybe it should be made a "sticky". Sorry, I didn't realize it already was a sticky!!!
I believe that if you have the PSD - 6.0L the tow capacity is 20,000. It is 13500 for the 5.4 with the 3.73 rear end and slightly higher with the 4.10 rear end.
The 7.3PSD had a tow capicity of 18000.
You can find all the information needed in a owners manual.
