Front Axle Compatibility
Old Jan 18, 2023 | 01:14 PM
brenjimin's Avatar
brenjimin
Trailering
Hi guys,
I know I've seen a thread on this somewhere but I can't seem to find it. I have a 66 4x4 F100 and I'm looking to go to disc brakes. In the interest of doing that and not having to deal with kingpins I was looking at a later 70s high pinion 44. Will everything bolt in? Wasn't there some issue with caster when you make that swap?
Old Jan 18, 2023 | 02:08 PM
panterazacc's Avatar
panterazacc
Originally Posted by brenjimin
Hi guys,
I swapped a '77 1/2 Dana 44 from an F250 with factory disc brakes no problem on my '64. Just needed to move the left shock tower 2 inches. Spring perches lined right up. I think caster and camber were fine. Shop never said anything after getting an alignment after I replaced the tie rod.
Old Jan 18, 2023 | 03:33 PM
panterazacc
Hi guys,
Old Jan 19, 2023 | 09:57 AM
brenjimin's Avatar
brenjimin
Trailering
That would be a different setup. 66 4x4 F100 is coil springs and radius arms.
Old Jan 19, 2023 | 11:53 AM
panterazacc
learning as I go! Sorry.
Old Jan 19, 2023 | 06:06 PM
53deere's Avatar
53deere
It should bolt in without any issues. Not sure if the caster will change but they make poly bushings to adjust caster if needed or possibly try to get strut bars along with the axle.
Old Jan 19, 2023 | 06:16 PM
brenjimin's Avatar
brenjimin
Trailering
All good, it was the first year for coils which is why info is so tough to find!
That's the impression that I got, it appears axle width, frame width, and track width are identical for all of the trucks in that Era but I could've sworn I saw a thread on it once upon a time!
Montanatexas
Oct 24, 2022 07:36 PM
46Whizzer
Feb 7, 2016 09:43 AM
dhobdey1
30
Jan 7, 2011 04:48 AM
steve664x4
Mar 22, 2006 09:00 AM
66 4x4
Offroad & 4x4
Mar 16, 2006 07:08 PM
