High idle help
Old Jan 17, 2023 | 08:08 AM
Lt96's Avatar
Lt96
High idle help
Help needed
1996 f150 4.9 5spd
Iam trying to diagnose my high idle (1000) engine warm, checked for vacuum leaks with smoke machine (home made) propane and a 1/4 hose and brake clean none found. Just tried to replace the iac valve and clear kam memory no change, disconnect iac valve no change on new and old iac have voltage on red lead to iac. I have no engine codes checked with quality scanner. Any suggestions iam think of replacing the tps next to see if that helps
Thanks in advance
Old Jan 17, 2023 | 08:32 AM
jas88's Avatar
jas88
Is this truck new to you and came this way? Or did it develop over time?
Old Jan 17, 2023 | 08:42 AM
Conanski's Avatar
Conanski
If unplugging the IAC makes no difference to idle speed then the motor either has a significant vacuum leak or the throttle blades are not fully closing. It seems you have already investigated for vacuum leaks so I'd suggest you take a closer look at throttle control. Possibilities include a binding throttle cable, a misadjusted throttle stop screw, and a warn or binding throttle linkage.
Old Jan 17, 2023 | 09:06 AM
Lt96's Avatar
Lt96
Truck came this way, Is it possible that previous owner installed tps wrong and its holding the throttle open ?. I plan on checking the tps tonight with multi meter. I know there is something about install and rotate anyone have a quick rundown on that thanks
Old Jan 17, 2023 | 10:19 AM
Prototypemech's Avatar
Prototypemech
Its very common for these trucks to have cracked vacuum hoses, which causes hi-idle. The PCV valve hose is a big offender. Carefully check all you vacuum hoses for breaks and cracks.
Old Jan 17, 2023 | 01:20 PM
jas88's Avatar
jas88
If it came that way, I bet the PO jacked the base idle screw out to compensate for a dirty IAC valve.
Old Jan 17, 2023 | 09:09 PM
Lt96's Avatar
Lt96
Update might have found something
So tonight I changed the tps and check its volts .88 closed and 4.68 wide open not perfect but in the ball park (aftermarket part) cleared my kam memory dropped idle to 808 to 850 ish so definitely a improvement. I can still disconnect the iac with no change so started looking for vac leak again, think I found it on the intake gasket to head near the front two cylinders. My question is with the propane rims didn't jump alot just a bit how can I verify 100% and why didn't the smoke show the leak. I must introducing the smoke into the hose off of the master brake ....
thanks
Old Jan 17, 2023 | 09:20 PM
Prototypemech
You can use a piece of 1/4" rubber or vinyl hose, put one end near your ear and the other end where you expect the leak is and move it around. If it's leaking, you'll hear it hiss.
Old Jan 17, 2023 | 09:46 PM
Lt96's Avatar
Lt96
Thanks ill give that a try
Old Jan 18, 2023 | 07:07 AM
rla2005's Avatar
rla2005
Anything between 0.67 to 1.0 VDC at closed throttle is text book perfect. The internet myth of the TPS has to be set to 0.99 VDC is just that...a myth. Leave the TPS alone and do not lose any sleep over a "not perfect" closed throttle TPS output. The WOT throttle value is good as well.
I sincerely hope that aftermarket TPS is not a short fuse in disguise.
Old Jan 18, 2023 | 09:08 AM
jas88's Avatar
jas88
You need to try backing off the base idle screw with IAC valve disconnected to see if that makes any change. I am not sure about the idle spec on the 4.9L, but IIRC on the 5.0L with manual trans it is about 850-900 RPM.
rj1983
May 3, 2017 04:04 PM
rj1983
Feb 4, 2017 04:26 PM
boice1971
Oct 1, 2015 10:03 PM
kjg26
Feb 10, 2006 01:10 PM
sjser
19
Oct 22, 2005 06:27 PM
