Iac
Old Feb 9, 2006 | 01:53 PM
kjg26's Avatar
kjg26
Iac
i've had high idle issues since i bought the truck almost a year ago. I started investigating the cause of the high idle. I unplugged the IAC electrical connector and the engine died almost instantly. Is that what is supposed to happen or is the IAC bad? i'll be checking to see if i have the correct voltage to the IAC as soon as i can get ahold of a voltmeter.
Thanks
Keith
Old Feb 9, 2006 | 03:44 PM
MemOrex's Avatar
MemOrex
It sounds like the IAC is functioning right. How high is the idle? Some things to look for are vacuum leaks.
Also, a bad TPS usually causes high idle.
Old Feb 9, 2006 | 04:27 PM
bjthemadboater's Avatar
bjthemadboater
how can u tell if the iac is bad and were is it
Old Feb 9, 2006 | 04:33 PM
bjthemadboater
the iac valve on a 97 expedition
it starts but it will not stay on if i don't keep my foot on the gas
Old Feb 9, 2006 | 04:48 PM
subford's Avatar
subford
If you have to keep your foot on the gas (throttle) to keep it running, then I would guess that you have a bad EGR valve. If that was your question.
Old Feb 9, 2006 | 04:51 PM
88FordF-150's Avatar
88FordF-150
No if he had to keep his foot on the gas i would say the iac motor is bad. Had a dodge neon in the shop the other day did the same exact thing. Turns out the iac was bad
Old Feb 9, 2006 | 05:11 PM
bjthemadboater
Iac Motor
Were Is The Iac Motor, If I Keep My On The Gas It Runs But If I Take It Off It Stops Running Thanks For Your Help AND SHOULD I CHANGES THE ERG TOO
Old Feb 9, 2006 | 05:16 PM
quicklook2's Avatar
quicklook2
you need to read codes.
iac is on the side of the throttle body.
do you have a manual yet?
get one if you do not have one.
Old Feb 9, 2006 | 05:27 PM
bjthemadboater
Iac Valve
Do It Have A Plug On It
Old Feb 9, 2006 | 05:33 PM
subford's Avatar
subford
You’re probably right about the IAC that would have been my second guess but I have had problems with EGR valve making them die.
It has a plug on it, here is a photo.
kjg26's Avatar
kjg26
yes it has a electircal connector. I do have a manual. it doesn't have anything on diagnosis of the IAC only how to remove and replace it. how do i test my TPS? the idle is 2000. would a clogged exhaust system make a high idle?
Old Feb 9, 2006 | 05:43 PM
subford's Avatar
subford
This will tell you what you want to know about the TPS.
http://fordfuelinjection.com/index.php?p=30
Old Feb 9, 2006 | 06:18 PM
bjthemadboater
Iac Valve
Thanks 4 Your Help I Am Trying To Get It Running So I Can Take My Boat Out Thanks Again
Old Feb 9, 2006 | 11:37 PM
MemOrex's Avatar
MemOrex
You need a voltmeter to test it. subford provided that link which shows the wire connections and what readings should be.... but a 2000 idle really does sound like TPS.
bjthemadboater, yes that does sound like a completetly closed IAC valve (or really clogged up..which can be cleaned). subford mentioned the EGR valve...that is a possibility if the valve was stuck open...but if this was the case, the truck would run bad all the time.
Old Feb 10, 2006 | 01:10 PM
kjg26's Avatar
kjg26
i'll take a look at the TPS this weekend sometime. how long should it take to remove and check/replace the TPS?
Thanks
Keith
