Stumbling at anytime
Old Jan 15, 2023 | 07:50 PM
Dnix86's Avatar
Dnix86
86, 302 EFI, auto. New iac, tps, plugs, wires, distributor cap and rotor, starter, solenoid and wire, temp sensor, positive and negative wires, vacuum can, battery, throttle cable. It's cutting out randomly. What am I missing? Thanks replaced TFI also
Old Jan 15, 2023 | 07:54 PM
Franklin2's Avatar
Franklin2
Pull the codes from the computer and see if they give any clues.
Old Jan 15, 2023 | 07:58 PM
Dnix86's Avatar
Dnix86
I'm new to this old of truck. What's the best way to do it? Thanks
Old Jan 15, 2023 | 08:13 PM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
were the parts replaced to try and fix this?
When you say "It's cutting out randomly" is the motor shutting off like the key was turned off?
If so replace the TFI in the dist. it is what the wires plug into on the dist.
But dose not hurt to pull codes
Dave ----
Old Jan 15, 2023 | 08:17 PM
Dnix86's Avatar
Dnix86
Yes, actually like it's getting shut off and back on again. I haven't pulled an distributor in a while. What's the best way to do it so when I put it back in I just have to retire it? Thanks.
Old Jan 15, 2023 | 08:20 PM
Dnix86's Avatar
Dnix86
I actually did replace it.
Old Jan 15, 2023 | 08:50 PM
Dnix86's Avatar
Dnix86
Of course my emissions light bulb is broken on the dash. Will have to replace it tomorrow. Thanks for the help
Old Jan 15, 2023 | 09:43 PM
Franklin2's Avatar
Franklin2
These old trucks do not have a conventional check engine light. The emission light is for something else. Here's how to pull the codes with a testlight.
Scroll down in this link and it explains it all. If you are going to keep this truck, it will be beneficial to know how to work on it and pull the codes from the computer.
https://www.troublecodes.net/ford/eectest/
Old Jan 16, 2023 | 08:00 AM
FuzzFace2's Avatar
FuzzFace2
So the distributor was replaced before or after this shutting down happened?
Dave ----
arussel88
Jan 3, 2019 11:06 AM
Fencemansc
Jul 20, 2013 06:52 AM
danjohnson67
Jun 15, 2011 03:24 PM
alie-r
May 13, 2011 09:38 PM
truckguy
Nov 23, 2003 08:45 PM
