Sponsored by: Auxito
Steering problem
Old Jan 15, 2023 | 11:02 AM
Justavet's Avatar
Justavet
Trailering
Steering problem
Hello all I replaced my driver side cv shaft and also fixed the camber while I was at it but I drove it yesterday was driving fine then all of a sudden the front tires seem to want to wobble/turn on their own. Got to where I was going and then left drove fine a few miles down the road it starts doing it again. The lug nuts are tight the cv shaft bolt is tight the idler arm and pitman arm were replaced about 3 weeks ago. I haven’t the slightest clue. It’s a 97 F150 4.6L V8
Old Jan 16, 2023 | 10:11 AM
manicmechanic007's Avatar
manicmechanic007
What do you mean by "fixed the camber"
If you changed the camber you changed the toe
They get a mind of their own when the toe is out of spec
Camber too but you get the toe close to zero and it should be better
Old Jan 16, 2023 | 10:34 AM
Justavet's Avatar
Justavet
Trailering
my bad meant adjusted the camber the driver side tire was / while the passenger tire was |. I didn’t think about the toe adjustment.
Old Jan 16, 2023 | 11:03 AM
manicmechanic007
You can use a stick and a tube to do a basic toe set
Put the stick inside the tube and hold it between the front tires in the front
Make a mark with a sharpie
Take the tube to the rear of the front tires and hold it in between. Check where your mark is
Adjust the toe until the marks are the same, front of the tire and rear of the tire
Old Jan 16, 2023 | 11:11 AM
Justavet's Avatar
Justavet
Trailering
ok thanks for the tips! 😎
75BigBlock
Apr 21, 2018 07:38 PM
Fordx4jake
May 31, 2015 12:02 PM
icemann21
Mar 30, 2013 09:24 PM
dichdoc
1978 - 1996 Big Bronco
Aug 31, 2006 09:00 PM
Moe Gendron
Jan 27, 2000 08:21 AM
