Help
Old Jan 14, 2023 | 10:31 PM
judie bootie's Avatar
judie bootie
4wd Low
Help
Big bang then when take my foot off clutch pedal loud whinning spinning noise.? What the hell happened? 1977 f150
Old Jan 14, 2023 | 11:37 PM
dlburch's Avatar
dlburch
partially depends on what you're working on? two-wheel drive or four-wheel drive? did you check your u-joints? does the truck try to move when in gear and letting the clutch out?
Old Jan 14, 2023 | 11:52 PM
judie bootie
4wd Low
Was going up hill on my way home from work, my road gets pretty muddy in the rain. I have a little timing issue also, so, sometimes up hill it loses a little power so I have to compensate with the gas pedal. Everyday I go up the same road in 4 wheel high in 2nd gear. No problem we'll it's been pouring rain for days . My road is snot now, instead of losing power in 2nd gear I chose to try granny in 4 high then big bang. Blabla please tell me I can fix my baby.
Old Jan 15, 2023 | 03:57 AM
Ozzie H.'s Avatar
Ozzie H.
Sure it's fixable. More investigation is needed to "nail down" what the problem really is. It might be the clutch. ??????
Old Jan 15, 2023 | 06:45 AM
Mark8man's Avatar
Mark8man
Lets try to narrow down. Does it do it (the bang) with transmission neutral by just pushing clutch in and out? Or do you have to be moving? If only when moving try shifting transfer case to 2HI and see if same result.
Old Jan 15, 2023 | 09:34 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If you used 1st (granny) gear and 4H, I hope you did not try to go faster than maybe 5/10 MPH. IMO 1st granny gear is for LOW speed operations, NOT getting up a snot slick road. I bet you had that motor wound out? So some questions now.
1. Did it make the noise once or does it make it every time you take your foot off the clutch? As in let the clutch out?
2. Does the truck move under it own power in all the gears in 2wd?
3. Does the trans shift normal now?
4. Does it make the noise in 2nd, 3rd gear 4H?
5. Have you got under the truck and insp the drive line. Meaning both drive shafts, u joints, and the front axle steering u joints?
Old Jan 15, 2023 | 12:00 PM
tbear853's Avatar
tbear853
Almost reads as if the throw-out bearing or pressure plate finger took a dive.
61Redneck
Sep 28, 2021 03:28 PM
hillcountryflt
25
Jun 2, 2016 03:45 PM
Jmatthews
Apr 15, 2010 06:32 PM
Kijutsu
1983 - 2012 Ranger & B-Series
Aug 1, 2007 04:59 PM
kinggargantuan
Nov 18, 2004 02:35 PM
