Truck not starting with new glow plugs
I have a 1993 ford f250 with the 7.3 idi. It was all fine until a couple weeks ago when it started hard starting. I assumed glow plugs as opposed to an air leak or something like that so I changed them all out. Truck still wouldn’t start, found an air leak around an injector and solved that issue but still no start. It would click for a while when the key was turned to the on position so now I assumed the co troller was dead. Instead of buying a new controller, I rigged up a pic button start in the cab and the truck fired right up. Worked fine for three starts until today when it failed to crank again. I assumed I hadn’t held the button long enough so I tried again and still nothing. Fearing burned up plugs I gave it a huff of starting fluid and it started up.
sorry for the long winded response but this is frustrating, I smelled something getting hot in the cab so maybe one of my connections? I can see the voltage drop when the button is pushed so something is getting power Not sure any info will help. Thanks
Received 3,150 Likes
on
Not sure, ordered a set of 8 off of diesel logic.com. I took one out and inspected it and it seems fine. The ones I tested had around 1.1 ohms of resistance, is this too high?. The relay clicked excessively before I did the push button swap so it’s probably dead. Would a dead relay still effect the plugs even with the manual override. Like I said it started fine 3 times.
on
you are lucky you got three starts out of them. most only work one time.
rock auto has the motorcraft ZD-9 plugs for $9.45 each
https://www.rockauto.com/en/cart/
thank you so much, I’ll order the new ones and get it all fixed up
The following users liked this post:
1984_IH6.9_Project
11-15-2016 06:25 PM
bettyford93
10-31-2014 11:45 AM
ALedbetter1
15
04-08-2013 10:22 PM
