Now that i have the truck back from the ppf shop im going to put on the luverne wheel to wheel boards and grille guard and work on a humidor. Im planning to cut out the bottom and mount a ceder box below it. Then i can make a holder for a boveta pack, and put some ceder on the bottom of the rubber insert so it all pops together.
I've had my F250 about 6 months and just discovered a secret compartment in the center console. You can lift up the tray using the center divider to pull it up and there is a nice place to hide your phone or other thin things if you wanted to. Then, if you pull up the flexible liner in this compartment there is a spot under there that looks like a spot to hide your key. Very cool, I thought. Are there any other secret spots I may not know about? I also figured out that the top of the two hole drink holder can slide to the left to create a spot for four drinks.
