Piston damage from glow plug
Old Jan 10, 2023 | 05:36 AM
RayMas's Avatar
RayMas
Trailering
Hey guys
i got this junkyard engine and started to reseal it and pulled the heads and found this. Looks pretty bad but I’ve seen a lot of people say some damage is ok, can I just blend this damage down smooth and run it? They say this engine ran fine a month ago when they pulled it.
I have a old 6.9 that ran without oil pressure and destroyed the bottom end, is it better to use a piston from that engine with new rings? I just get nervous swapping used pistons, I feel like that can have more issues down the road.
Old Jan 10, 2023 | 06:37 AM
Olds64's Avatar
Olds64
If you aren't taking the engine to the machinist, I would just re-use the piston, install new rings and hone the cylinders.
Old Jan 10, 2023 | 09:28 AM
Prototypemech's Avatar
Prototypemech
If youre not doing a complete rebuild, I'd just blend out the damage with an air-grinder with a sanding disc on it. Dont even bother to pull the piston out; just blend it in-place. The cylinder walls look pretty good.
Old Jan 10, 2023 | 09:47 AM
RayMas's Avatar
RayMas
Trailering
The walls are very clean, the reflection is deceiving but they are clean.
RBRASWELL1
Oct 24, 2022 08:01 AM
DarkOverCast
128
Mar 10, 2021 12:28 AM
geoffryhildebrand
Dec 26, 2020 08:00 AM
FastTruck
Jan 18, 2018 01:36 PM
Royson12
37
Mar 7, 2011 08:14 PM
