300 wire harness
I was happy to get through a 100% rewire for various reasons, but in doing so I realized that I could have definitely repaired what I had for a small fraction of the price and effort. Also, the rewire cost even more because I was inspired to add or upgrade this and that and throw money at it while I was doing the work.
What's your starting point, goals and needs?
These are simple electrical systems and you might be able to splice and dice your way to a running and reliable machine.
The positive side is 'wired' to the starter, but the negative side needs to travel through the bell housing, then usually the block then some strap or cable to the frame or body and then to the neg battery post. (A new harness kit will probably not include any negative side items, so a new kit doesn't even address the most likely issue).
Find the total path from the starter housing to the neg post of the battery. Remove and clean any cable type connections, including at the battery post. A basic job will likely do it, but I like to remove the connections, use sand paper or wire brush, to clean to bright shiny metal, then put a bit of grease on it, then re-attach tightly. The metal squeezes the grease away and makes contact, but the grease keeps if from re-oxidizing too quickly.
If that doesn't fix it, do the same thing for the positive side of the connection between the battery post and the starter. Even if it looks good, remove, clean and replace all the connections points.
BTW, my truck likes to fail at the positive post of the battery - if it doesn't crank, I loosen and move around and re-tighten the positive post cable clamp, and then it starts right up.
I also had a problem where the battery clamp was not connected well to the battery cable - I soldered it up solid and the problem went away.
In general, electrical systems fail at the connectors - either where the wires go into the back of the connector, or at the actual connection point - so look at all of those.
gauge feed harness Dennis Carpenter Ford Restoration Parts for Trucks, Broncos, Cars, Tractors and Cushman Scooters (dennis-carpenter.com)
At the very least you need the dash to engine harness. The connector plugs at the firewall are very prone to corrosion and can be difficult to unplug. Use a rolled-up piece of sandpaper and clean them up. It doesn't hurt to put a little silicone dielectric paste on them before you plug them in. The re-pop harnesses are plug and play with all the correct connectors and wire colors.
It could also be something like a bunch of paint between the starter face and bell housing, but I doubt it.
Also check your battery cables on both sides where the cable is inserted into the clamp or lug. I had to add solder to mine to get a good connection
If your negative side is good, then you need to check the positive side connections at the battery, solenoid and starter.
It's a simple system - you don't need a new 'harness' if the solenoid is clicking. Provided the solenoid is clicking, then the only wiring harness problem would be those large positive or large negative cables from the battery to the starter.
If those cables and connections are good, then you need to re consider your battery, solenoid or starter.
There are a number of ways to trouble shoot this, with an ohmmeter or voltmeter or by hardware or cable swapping or bypassing the solenoid. For instance you can bypass the solenoid by using a remote starter or simply removing the battery side off the solenoid post, and touching it against the starter side of the solenoid.
Since you said you replaced battery, solenoid and starter and then had the same results, I would still be looking for a bad cable - particularly where the wires go into the eye ring or battery clamp - or a poor connection due to rust or some other problem. Next, based on my experiences, I would question the battery. It should be putting out 12.5 volts or so if you measure it with a voltmeter.
