No start electrical issues
Old Jan 8, 2023 | 10:26 AM
DJ17490's Avatar
DJ17490
Right so I have a 1988 F250 with a 460. Its got a new battery, new solenoid, and new main ground and main positive wires, however I am unable to get it to start, it just clicks really fast when I try to. I made sure all the solenoid wires are in the right spot, and the starter itself has a new ground as well, I'm not sure if my starter got fried or if a fuse blew or what when I replaced the grounds. What's the best way to test the starter if I need to?
Old Jan 8, 2023 | 11:18 AM
toolman60's Avatar
toolman60
This video will show you how to bypass the solenoid and wiring to switch to see if problem is starter.
Old Jan 8, 2023 | 11:34 AM
DJ17490's Avatar
DJ17490
Originally Posted by toolman60
This video will show you how to bypass the solenoid and wiring to switch to see if problem is starter. https://www.youtube.com/watch?v=SJL0DD8gJbY
The solenoid/relay is brand new, I've replaced it twice now even, so that shouldn't be the issue
Old Jan 8, 2023 | 12:40 PM
toolman60's Avatar
toolman60
Ok you turn key to start it just clicks. So to eliminate the starter if it cranks and starts at the solenoid you know the starter and starter cable and ground are good.
That will lead to the problem being from Ignition switch to the solenoid Yes? Not from Ignition switch all the way to the starter. Got to start diagnosing somewhere so I chose the solenoid. Now if you wish to start by taking the ignition switch off the column feel free to do so.
The fore mentioned video shows you how to test the starter.
And new does not mean it's good.
Old Jan 8, 2023 | 12:46 PM
joey2fords's Avatar
joey2fords
even so, it's a good idea to isolate the starter as per the video so that you can confirm whether or not it is the issue. also, i see new relays selling for as little as $6.00US. if you are buying cheap relays, that could be an issue.
Old Jan 8, 2023 | 01:11 PM
DJ17490's Avatar
DJ17490
The little trick the video shows with the screwdriver to the solenoid/relay didn't work, it just sparked and did nothing
Old Jan 8, 2023 | 01:18 PM
toolman60's Avatar
toolman60
Then I would disconnect battery check the cables between solenoid and starter, solenoid and battery and the battery cable ends and the grounds before I pulled starter to have it bench tested.
Old Jan 8, 2023 | 01:27 PM
DJ17490's Avatar
DJ17490
The main ground is new, the solenoid ground is new, the starter ground is also new, and so is the positive battery cable, ans the terminals are also new
Old Jan 8, 2023 | 02:09 PM
toolman60's Avatar
toolman60
Then it would be time to pull starter and bench test it.
Old Jan 9, 2023 | 12:02 AM
Prototypemech's Avatar
Prototypemech
Take a photo of you engine compartment and post it here.
Old Jan 11, 2023 | 12:03 PM
DJ17490's Avatar
DJ17490
Well, checked all my connections, they're good, all the larger wires are new, main ground, solenoid ground, and starter ground, as well as the positive wire, terminals are new, solenoids new, batteries new, starters new, got it tested and it was bad, and it's still doing the same damn thing.
Old Jan 11, 2023 | 01:01 PM
toolman60's Avatar
toolman60
1) Does the motor turn over by hand using a socket on crank bolt? Just eliminating a locked up motor.
2) Is it the correct starter for that engine?
Give us some details on what happened and why you made all these changes. Was truck running before and then just would not start. Is it automatic/manual all we know now is 88 F250 w 460 motor.
Old Jan 12, 2023 | 05:39 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have replaced 6 brand new starter relays that were bad out of the box. the only way to know for sure if they are good or bad is to bypass it and see if the truck starts.
Old Jan 12, 2023 | 08:20 AM
toolman60's Avatar
toolman60
OP stated he tried and it would not start that it just arched when he jumped solenoid.
Old Jan 12, 2023 | 09:23 AM
tjc transport
i ain't rite
Very possible the main battery cable at starter is twisted enough to be shorted to ground
Chris Tomlinson
Apr 30, 2021 08:35 AM
rustyruststang50
Apr 8, 2015 09:28 AM
ConorsTowing
Jul 1, 2012 08:29 PM
robinsonpowerstroke
Apr 5, 2012 10:58 AM
trigeek22
Jul 29, 2010 09:31 PM
