'90 F250 351W - Rough Starting after Smog Delete
So 2 lines from the EVR only...1 to the EGR as I've got it and the other to the vacuum tree on the manifold. That's all.
Similar to the diagram listed belowthat also shows how the air injection system is plumbed in.
Vacuum Diagram
The EVR/EGR vacuum supply needs to be tied into the vacuum reservoir on the passenger side inner fender. Under low vacuum conditions the reservoir supplies vacuum to the EGR system.
Vacuum Diagram
Vacuum Diagram
Then another line vac cannister to intake manifold.
My vac cannister is the later model, 2-chamber plastic one.
That still chokes the truck when starting.
I either can't figure out the correct combination of those vac lines or there's another issue.
I thought this would have been a little simpler with the air injection system removed. Been a wicked pain for something stupid.
I have not. It's fairly new, not that it means it can't be bad, but everything has just surrounded the smog system.
Reconfigured the lines yesterday to be more like the diagram:
EVR to EGR - as it has been.
EVR to vac cannister (top chamber. Bottom chamber ports are capped)
Vac cannister to intake manifold
I tried a few other ways but the truck wouldn't run. This routing incorporates the intake manifold and the symptoms are still the same as they have been.
I let the truck idle up to operating temp and manually rev'd the truck up for a minute to try and visually see the EGR valve move. Didn't see anything but I do see an orange-painted ring sticking up so I'm not sure if that's the valve stuck open. Not a lot of room to see.
If the EGR wasn't functioning, I've got to believe the truck wouldn't run or idle right while driving. It seems to run no problem. Just when starting past its initial start of the day. Which is why something stuck open allowing gases to sit, would choke it for a few seconds when starting.
on
With that setup correctly and engine idling the EGR valve should be closed so no vacuum coming from the solenoid, if there is disconnect the electrical plug to the solenoid, if that closes the solenoid it is OK but you have an electrical problem between the solenoid and PCM.. either a short, miswire, or faulty computer.
In case you haven't figured this out yet it mattters which port on the vac canister is connected to the vacuum source, I can't remember if it's left or right but try both.. in one position no vacuum is generated at the other port. And same applied to the EGR solenoid.. the bottom port is vacuum source(from vac res), top port goes to EGR valve.
I did see that on the vac cannister. On the left, it's got tiny stamped letters saying "vac." Never knew that until I took it out to clean it last year.
So the way I have the lines ran now, you think that (in theory) should be good? If everything else was working correctly.
Josh Schmit
06-04-2018 02:43 PM
zspeed130
09-28-2014 10:24 AM
BRay09
08-28-2010 09:19 PM
muscletruck7379
1983 - 2012 Ranger & B-Series
11-26-2004 12:19 AM
