Vacuum lines or no?
Old Mar 9, 2017 | 03:48 PM
79rangerxlt's Avatar
79rangerxlt
Vacuum lines or no?
Truck: 79 f250, 400, c6 trans, 4x4
Bare with me, I literally just picked this truck up this afternoon after looking at it, going over it, test driving it for a whole week. I finally bit the bullet and bought it. Anyways I need to know what this is? (Picture). Located on passenger side, on outside frame rail, under the cab door. Has a few lines that go to the engine bay. I noticed 2 are cut and a 3rd is connected to some kind vacuum fitting.
The awesome truck I just bought!
anyways do I need these two things? The back one doesn't even look like it's in use.
Thanks
Old Mar 9, 2017 | 06:51 PM
1996_5.8's Avatar
1996_5.8
Looks to be 2 charcoal canisters, for your emissions. Make sure they are either plugged in off capped off so they don't cause a vacuum leak.
By the way nice truck, how much did you pick it up for?
Old Mar 9, 2017 | 07:18 PM
tabascom16's Avatar
tabascom16
Yep...charcoal canisters as part of the emissions system. You should probably have a line running back to your gas tank and then another line up to the carburetor or intake.
No you don't need them if your area isn't a stickler for period correct emissions components.
Old Mar 9, 2017 | 07:38 PM
79rangerxlt
Thanks for info. I'll have to check the lines back to the tank, I know a few are old and broken or not even used.
I got the truck for 4200. Runs like a champ.
at 38 years old it's hard to tell what's stock and what's not
Old Mar 9, 2017 | 07:55 PM
1996_5.8's Avatar
1996_5.8
Wow 4200? I just bought my 74 for 4400, hows the interior and engine look?
Old Mar 9, 2017 | 08:35 PM
79rangerxlt
The seat was reupholster. Floor pans replaced, but not great, I'll be redoing it. No ac or heat. No radio. Overall 7 out of 10 interior.
engine leaks at the valve covers but over all clean. Still has the 2 barrel carb. Doing a fitech tbi.
Old Mar 9, 2017 | 08:56 PM
1996_5.8's Avatar
1996_5.8
Good buy, I have a 390 with factory air, ps, pb, and its a 4 speed with an eldelbrock carb and intake. Lets just say she likes to chirp the tires
Old Mar 9, 2017 | 09:15 PM
79rangerxlt
Thanks man. I really wanted a 4 speed. But the c6 will do. I'll be towing my toyota rock crawler around just fine with it and my DD. I just want to make it a reliable beast!
Old Mar 9, 2017 | 09:32 PM
PapaBearYuma's Avatar
PapaBearYuma
Thanks
Welcome to FTE!!! Lots of good people here, often willing to help out...
That's a good-looking truck, and it looks to be in very good shape. Score!
As others have said, those appear to be charcoal canisters for the emissions. They'll connect to the port on top of the gas tank(s) and to the carb/air cleaner.
Old Mar 9, 2017 | 10:05 PM
79rangerxlt
Thanks I appreciate the welcome! I was all over this site when deciding if I wanted to buy it. Lots of good info and some good people.
James Wagoner
18
May 19, 2018 12:11 AM
65fordguy
36
Aug 19, 2017 08:52 AM
SegF250Ranger
Sep 12, 2016 09:31 AM
Wolfmancc
1978 - 1996 Big Bronco
Oct 6, 2015 01:22 PM
jgavac
Dec 25, 2011 03:23 PM
