Washer pump circuit
Old Jan 8, 2023 | 08:11 AM
Bullnose010's Avatar
Bullnose010
Washer pump circuit
My wipers operating correctly when i turn the wiper ****, but when i (de)press the **** it does nothing.
I can see that the factory washer pump is replaced with an another one.
Is there a fuse /switch or something else what i should check before I gonna check if the pump works ?
They put also a aftermarket switch under the dash panel.🤷🏻‍♂️
Old Jan 8, 2023 | 11:00 AM
BigBlue2's Avatar
BigBlue2
The wiper switch looks aftermarket as well. You could run a 12v jumper wire to the pump for starters to see if it's still good. Then work your way back through switches and fuses.
Old Jan 8, 2023 | 04:57 PM
FuzzFace2's Avatar
FuzzFace2
That aftermarket pump dose it have 2 wires going to it and 1 of them to a good ground?
I would then take a test light and see if you have power to the other wire when you use either switch.
As a guess that switch under the dash is a pump switch with a new wire to the pump but where did they get power from?
And you would still need to turn the factory **** for the wipers to move.
Could the push of the factory **** be blocked by that bolt holding the **** on hitting the dash?
Dave ----
Old Jan 8, 2023 | 05:19 PM
Franklin2's Avatar
Franklin2
Here's a diagram for the washer circuit.
Old Jan 9, 2023 | 09:18 AM
monkey-1's Avatar
monkey-1
During the rebuild of our '85, our original tank was cracked. Since we were using a Grand Marquis (same as Crown Vic) as a donor, we had all of the parts left over. The tank from the donor is a perfect fit on the inner fender and we wired back to the pump to the factory truck switch. If memory serves, we used a factory hole and drilled another with a nutsert to mount.
Dhouse77
Large Truck
Sep 25, 2021 04:27 PM
qman
13
Sep 3, 2021 05:02 PM
rock2610d
Oct 23, 2020 09:13 PM
krabbekrout
Sep 12, 2020 04:59 PM
DJ_Magic_Mike
Sep 9, 2016 10:49 PM
