Went and got an oil change for my 97 f150 and they put 5w20 in instead of 5w30 would that cause problems? Should I replace the oil with the recommended type?
As a Ford tech, I cringed each couple of years as they thinned out the oils in search of fuel mileage (all of us did I think)
The thin oil is a necessity with the closer piston and bearing clearances the new engines have
Real glad to see some manufacturers bringing back the thicker stuff like BMW 0-50, 5-40 and the like
