Mercon V Alternatives?
Old Jan 7, 2023 | 03:06 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Mercon V appears to be super expensive everywhere these days, so I have a question:
1999 F-350 7.3 and 1999 F-53 V-10 motorhome, both with 4R100s. The F-53 is around 16,500 pounds empty and the F-350 is used for towing and hauling most of its miles, so both work for a living. I like to keep good fluids in them.
I've been using Mercon V based on lots of research and @Mark Kovalsky's advice over in: https://www.ford-trucks.com/forums/1...mendation.html
Unfortunately, the price of Mercon V has gone way up, availability has gone way down, and I need to do a service on the F-350. The owner's manual calls for Mercon ATF, but it has Mercon V in it. I've also seen notices everywhere (including the owner's manual) that the two fluids aren't compatible and never mix them together etc.
So . . . my choices are:
- Wait for prices to come down
- Pay an exorbitant price for name brand Mercon V
- Use a bargain brand Mercon V
- Switch to name brand Mercon ATF
I keep a close eye on fluids and maintenance either way, and I would expect to change bargain brand or Mercon ATF more often.
Thoughts?
Old Jan 7, 2023 | 03:12 PM
diggerrigger's Avatar
diggerrigger
This doesn't help you now but I just bought 15 qts of Valvoline Mercon V from NAPA in December @ 6.99/qt. It does go on sale.
Old Jan 7, 2023 | 04:15 PM
CathedralCub
FTE Community Team
Thanks! That's what I usually use. It's over $15.00/quart around here, and that's if I can even find it.
Old Jan 7, 2023 | 05:26 PM
carbonation's Avatar
carbonation
Valvoline Maxlife Multi-Vehicle.
25.92 a gallon at WalMart.
Old Jan 7, 2023 | 07:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If it has a MERCON V rating, then Ford has tested it and it meets the MERCON V specification.
Where would you get MERCON? Ford stopped licensing MERCON in 2006. Nobody has made MERCON since then.
You can find DEX/MERC that says it is for use in transmissions that used MERCON or DEXRON. But nobody licences that fluid, so they can put ANYTHING in the bottle and call it DEX/MERC. Does it meet the now obsolete MERCON spec? Nobody knows. They could literally put straight 30 weight oil and there and call it DEX/MERC.
Old Jan 7, 2023 | 07:34 PM
00t444e's Avatar
00t444e
I have used this for years on transmissions and transfer cases that call for Mercon, never had any problems.
Old Jan 7, 2023 | 07:52 PM
Mark Kovalsky
That's one example of the DEX/MERC that I mentioned, above.
Old Jan 7, 2023 | 08:31 PM
00t444e's Avatar
00t444e
It is fine according to Blackstone analysis.
Old Jan 7, 2023 | 09:03 PM
Mark Kovalsky
Blackstone says that it meets the non-existant MERCON specification?
Old Jan 8, 2023 | 05:24 AM
JWA's Avatar
JWA
I'd ask how many miles on these transmissions and what is your normal mileage when you've done the full fluid exchange in the past?
You don't show your location but if you have Amazon delivery available I'd search for a known good quality brand Mercon V ATF there---I've done that to great success and do not use their "prime" scam.
MC Mercon V ATF MC Mercon V ATF
At that current price it works out to about $8.60/qt.
I too would have a problem paying $15/qt however when comparing a replacement cost of the transmission it seems a rather paltry cost all things considered.
First time I did Mark K's flush the dealership beat NAPA and others price-per-quart by almost $2. I did buy 24 quarts but that quantity didn't affect the cost from any place I checked. Unfortunately my dealership of the time only sold AFT by the quart, wouldn't supply the 5 quart jugs as shown in the above Amazon link.
Do keep in mind I'm not budget restrained and tend to buy "the best" products keeping my Ford E-Series vans working---they're my source of income so simply don't spare the expense. I'm sure there are quite a few high quality AFT's suitable for Mercon V specified applications but Motorcraft is my go to brand as I'm very confident its up to the need. I'm not pulling heavy loads or running past my chassis rated GVWR but my 2002 E-350 does weigh about 8.400 #, the 4R75-E transmission in place. I also switched my full fluid exchange interval to 30K instead of the 50K I thought was recommended. Blackstone and a few others here suggested the internal change.
Hope something here helps and good luck shopping!
Old Jan 8, 2023 | 09:45 AM
00t444e's Avatar
00t444e
Just because Ford quit making it doesn't mean the specs have disappeared.
Old Jan 8, 2023 | 12:01 PM
CathedralCub
FTE Community Team
I saw this, but no Mercon or Mercon V specification, just Mercon LV which is not compatible as far as I know:
Old Jan 8, 2023 | 12:22 PM
CathedralCub
FTE Community Team
Good to know, but at the same time I want to use stuff that's as high quality as I can reasonably get. Mobil 1 Mercon V will hold up a lot better near the limits of the specification than some lesser brands that just barely meet the specification. Your example of the Baja transmissions with the melted solder is a good example. If I just drove an F-250 that is mostly used like a Buick and only occasionally carried some 2x4's then I wouldn't be worried about it so much. The F-350 mostly tows and hauls, and the F-53's 4R100 never ever sees easy service, except at idle in Park.
Sorry, I was using the term "Mercon" too loosely. I was referring to the fluids that claim to be Mercon compatible like Supertech's "For use in Vehicles Previously Serviceable by DEXRON-III or MERCON Transmission Fluid". It doesn't say what it is certified and/or licensed as, just what the manufacturer intends it to be used for, which I'm sure their lawyers would claim is merely their opinion were I to have a provable issue.
You can find DEX/MERC that says it is for use in transmissions that used MERCON or DEXRON. But nobody licenses that fluid, so they can put ANYTHING in the bottle and call it DEX/MERC. Does it meet the now obsolete MERCON spec? Nobody knows. They could literally put straight 30 weight oil and there and call it DEX/MERC.
I agree entirely.
Old Jan 8, 2023 | 12:26 PM
CathedralCub
FTE Community Team
I appreciate this, I'm just scared of the actual description "For use in Vehicles Previously Serviceable by DEXRON-III or MERCON Transmission Fluid". It doesn't say what it is certified and/or licensed as, just what the manufacturer intends it to be used for, which I'm sure their lawyers would claim is merely their opinion were I to have a provable issue.
If these were light duty I'd think differently.
Last edited by CathedralCub; Aug 2, 2025 at 06:45 PM. Reason: Changed font from black to automatic for readability in dark mode
Old Jan 8, 2023 | 12:42 PM
00t444e's Avatar
00t444e
After over 10 years and hundreds of thousands of miles of use in multiple vehicles with out a single fluid related issue I am not too worried.
