C6 filter kit difference
Old Jan 6, 2023 | 02:42 PM
Bullnose010's Avatar
Bullnose010
Hi,
just bought this 2 kits for my '83 F350 4WD C6.
But why has one a metal gasket? And the other paper gasket?
Old Jan 6, 2023 | 07:17 PM
Franklin2's Avatar
Franklin2
Different brands. That is a different cork material also. I think you will find the cork material on the left to be better than the one on the right.
Old Jan 6, 2023 | 08:14 PM
kenny nunez's Avatar
kenny nunez
Filter gasket
2Xs on the left kit. The pan gasket material is better than the “generic brand”
Stand a female end of a 3/8” extension up in a vise to back up each mounting hole and with a ball peen hammer dimple back each oil pan mounting hole to compress the gasket evenly.
Old Jan 7, 2023 | 04:57 AM
Bullnose010
What about the filter gaskets ? The left one is metal and the right one is paper? Which one should I use?
Old Jan 7, 2023 | 08:19 AM
Franklin2's Avatar
Franklin2
I have no idea which one is preferred on those. That just seals the filter correct? If it leaks a little bit I would not think that would be a very big deal, since it's submerged in fluid all the time outside and inside anyway.
PM Mark Kovalsky. He is the resident expert on transmissions. https://www.ford-trucks.com/forums/member.php?u=23422
Old Jan 7, 2023 | 10:36 AM
White Lightnin''s Avatar
White Lightnin'
Cheap kit on the right, quality kit on the left, simple as that.
Old Jan 7, 2023 | 11:09 AM
Bullnose010
Very interesting, because the shop owner told me that the rebuild guys always choose for he right one... So i decide to get 1 of each instead of 2 Acdelco's...
Old Jan 8, 2023 | 06:45 AM
FuzzFace2's Avatar
FuzzFace2
Every bit saved on parts is more profit and as DaveF said if it is in fluid who would know if the gasket did not seal?
Dave ----
Old Jan 8, 2023 | 09:45 AM
White Lightnin'
I'm sure he does, it's the cheapest.
Laggy
Apr 14, 2020 12:09 AM
blackelim
May 30, 2018 12:30 AM
Coastal68
May 22, 2016 02:40 PM
arkredneck
1978 - 1996 Big Bronco
Oct 16, 2015 05:50 AM
JIMY
Sep 2, 2004 04:21 AM
