Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
LTL 9000 decode
Old Jan 5, 2023 | 11:32 AM
68crackerbox's Avatar
68crackerbox
4wd Low
LTL 9000 decode
this is a early LTL9000 could you decode for me please
this is an early LTL9000
Old Jan 5, 2023 | 01:26 PM
85e150's Avatar
85e150
You asked this back in July and I wasn't able to figure it out. I'm working on it--
It has serial number for 1977, but the model code only comes up for 1978 as a DSO.
Does it have a gas or diesel engine?
I'll be back later today on this.
Old Jan 5, 2023 | 02:16 PM
68crackerbox
4wd Low
it is diesel NTC 350 cummins not sure year would have to be 76 -78 thank you.
Old Jan 5, 2023 | 05:17 PM
85e150's Avatar
85e150
A90 = 1978 and later DSO. A Domestic Special Order. *
L = Cummins NTC 350
V = Kentucky Truck Plant
026845 = 1977 numerical series, September 1976 production*
204 = 204 inch wheelbase
3 = Dark Red Metallic
A900 = 1978-on LT900 DSO, 44,800 lbs GVWR*
HG8 = I don't have upholstrey info, but it looks like Custom Cab without butterfly hood.
No transmission, probably part of the special order
No rear axle, again, probably part of the special order
P = Rockwell (Timken) model FF-903 front axle, 12,000 lbs capacity with power steering
44800 = 44,800 lbs GVWR
87026
87 = Body Company
0206 = Special Order Number
* I can't explain the discrepancy in the production serial number and month of scheduled production, which would point to a 1977 model, vs. the model designation etc that points to a 1978 model. All of these under "A90" were special order trucks. That it was sold to a body company, plus the transmission and axle being part of the special order might have something to do with it.
Is there any other history, or company markings or other clues about it?
I take it the truck is badged as "LTL 9000"?
Old Jan 5, 2023 | 07:44 PM
68crackerbox
4wd Low
Thank you so much. I thinking the date differnce is it was built then sent out to Able body to have the sleeper put on.then went to a dealer to sell.
Old Jan 5, 2023 | 07:56 PM
68crackerbox
4wd Low
this is the truck LTL 9000
Brentikus405
Large Truck
May 11, 2021 06:07 PM
Mattrl1985
Large Truck
21
Aug 17, 2020 07:42 PM
Hesson81
49
Feb 27, 2020 10:33 PM
Ron94150
6.2L V8
16
Apr 12, 2019 02:34 PM
