Removing smog pump question
Old Jan 4, 2023 | 03:27 PM
1ole4d's Avatar
1ole4d
I'm getting ready to swap out the 302 in my '89 that has a smog pump. The replacement is from a '96 Explorer and does not have smog equipment. I'm already having issues with the air tube that's behind the converter and it's making the check engine light come on/flicker. I started thinking...if I remove the smog system completely won't the check engine light stay on? If so is there a way to fool the ecm into thinking it's still there?
Old Jan 4, 2023 | 05:17 PM
Hit Man X's Avatar
Hit Man X
Use your original brackets.
Old Jan 4, 2023 | 06:52 PM
R&RFord's Avatar
R&RFord
You can remove the secondary AIR system. Just leave the control solenoids hooked up to the electrical harness. You will have codes if you run KOER diagnostics but no MIL.
The EGR system should be left intact. If you want to stop the carbon entering the intake tract block the exhaust supply. This will allow the valve to operate normally, keeping the computer happy, and put a real damper on sludge build up.
Old Jan 6, 2023 | 08:06 AM
Toork's Avatar
Toork
I removed my smog pump but left all the vacuum attachments intact. I have no codes. I just run a shorter belt with no problems. 97 5.8l.
Old Jan 6, 2023 | 10:34 AM
Conanski's Avatar
Conanski
How do you know that? Have you pulled codes?
xc4jokestomper
28
Jul 19, 2025 10:38 PM
Thomscottson
42
Feb 14, 2019 07:00 PM
Hotroddaddy62
Aug 15, 2013 05:27 PM
jagtech
Jun 1, 2009 05:38 PM
sgreen
Jan 26, 2004 07:59 AM
