Smog pump - 7.5 l
Old May 31, 2009 | 06:50 PM
jagtech's Avatar
jagtech
Smog pump - 7.5 l
Hello, first time here...
The smog pump on my 7.5 l V-8 is going bad, and I did a search for topics relating to this. I found numerous mentions about removing the system completely.
My question is: can I just remove the belt from the air pump, use a shorter one, and leave the dead pump and all other associated components in place? Will this cause any problems?
Many thanx.
Old May 31, 2009 | 09:23 PM
Big89Dumper's Avatar
Big89Dumper
I would also like to see some info on this. I Often wondered what it is for and if I can remove it without messing something up.
Old May 31, 2009 | 09:55 PM
DIYiT's Avatar
DIYiT
Removing the air pump from the system will kill the cat in time. However, if you have removed the cat already, you should be able to remove the air pump with no ill effects (as far as I know). I too am curious on how exactly to remove the air pump from the system however, so I'm looking forward to the outcome of this thread.
Old Jun 1, 2009 | 05:38 PM
jagtech's Avatar
jagtech
I'm really not keen to physically remove the pump, or other pieces of the system. Also still have the cat.
It looks like I can make a shorter belt work, but might have to take the pulley off the air pump, for clearance reasons.
Can I just use a shorter belt, and let the dead pump remain on the engine fully connected?
Will this damage anything, or have negative effect on mileage?
(97 Ford 460 F-53)
BigBlocker0248
Nov 4, 2016 09:24 AM
rgrandma
Dec 17, 2015 07:51 AM
Richard Gaytan
Oct 21, 2015 04:03 PM
sparr0
Aug 14, 2015 10:04 PM
oakwith
Jul 24, 2007 06:46 PM
