Cab floor differences
Old Jan 3, 2023 | 02:33 PM
rusderr's Avatar
rusderr
4wd Low
Need help understanding the differences between the 2 cab floor options during this year. I have a 1966 F100 2wd cab and it has a lot of work to fix all the holes and rust in the floor. I went searching for a complete cab floor option on the interwebs and all I can find for a complete replacement floor has the step up recessed door section. see pic. Since mine does not and you cant get LMC or anyone to give you measurements, I just don't know if it will fit well? I suppose it will as I have not seen any 64-66 doors that look different on the bottom section. If anyone has information, please let me know. The door area is the big question.
Old Jan 3, 2023 | 02:43 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I think you'd be better off with the 1967-1972 cab floor. This has the same opening as the 1965/66 2WD trucks. My 1966 F250 4WD uses the taller step floor like you posted, so same year but used the other design.
CJ Classic Trucks F-100 Cab Floor Assembly Complete High Hump Steel E-Coated 1967-1972 (cjponyparts.com)
Old Jan 3, 2023 | 02:47 PM
doug64f100's Avatar
doug64f100
The cab mounting is different between those two floors as well. That step floor will not work with your cab that I know of.
Doug
Old Jan 3, 2023 | 02:52 PM
rusderr's Avatar
rusderr
4wd Low
WOW... I have spent so much time trying to find that part and your are auto-magic......many thanks. That looks perfect, and cheaper.
Now I see the difference. the year!! thanks for the information as that helps a bunch. and the step up is the 4x4 version.
Old Jan 3, 2023 | 06:44 PM
53deere's Avatar
53deere
The floor with the steps is all trucks up through 64, all 4x4 and F350 in 65, and F250 4x4 and F350 in 66.
Looks like you have a 66 F100 4x4 which is the only 4x4 that used the same floor (like the 67-72 floor) as the Twin I Beam 2WD trucks.
Post some pictures of your, always like to see photos of the 4x4s.
aagiv
Dec 26, 2021 09:06 AM
Squeak51
Jun 5, 2020 12:29 PM
Srowe
20
Mar 13, 2020 07:24 AM
lucas56
Feb 16, 2020 05:16 PM
mwoj
Jun 18, 2017 08:49 PM
