Hard shifting E4OD
Old Jan 2, 2023 | 08:50 PM
Dads79's Avatar
Dads79
Hard shifting E4OD
Hello all. I have a really nice original 1992 F-250 Supercab 2wd Xlt . 460 with an E4OD that is a Jasper rebuild with about 6000 miles on it. Lately it has been shifting hard ,mainly 1st to 2nd and 3rd to OD . I have replaced the MLPS and TPS. I had it scanned , and it came back with code 99 idle not learned / electronic pressure control circuit fault. I pulled the wiring harness going to transmission, and looked it and the pins over for any damage ,found none. The over drive button on end of shift is not flashing . I have no CEL ,everything else is working as it should. Cant find any info on this code in my Chiltons manual . Anyone have an issue like this . Your help is appreciated .
Old Jan 2, 2023 | 09:17 PM
Conanski's Avatar
Conanski
The default mode the Computer switches to when there is a sensor problem is to jack up trans line pressure which results in hard/late shifts, so you need to find out what problem the computer is seeing. The Equus3145 code reader will make pulling codes real easy... and it's not an expensive tool to buy.
Old Jan 2, 2023 | 09:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A Chilton's manual is useful for lining a birdcage, but not much more than that.
The code for the electrical circuit fault is your problem. Looking at the wiring is a waste of time. You need to electrically check the circuit to the EPC (Electronic Pressure Control) solenoid for opens, short to power, and short to ground. Anything less than this won't fix it.
You can read the codes on a 1992 with a paper clip. www.troublecodes.net/ford
Jwalker371
Jan 28, 2022 03:25 PM
strokepower2019
Dec 4, 2021 03:42 PM
ml8on
1978 - 1996 Big Bronco
15
Apr 23, 2014 11:58 AM
