Help please!
Old Jan 1, 2023 | 04:10 PM
Wormhole83's Avatar
Wormhole83
2nd Gear
Help please!
My 85 f150 quit on me and I can’t seem to get going again. I had an issue with the timing so I got the compression stroke to top dead center and the harmonic balancer set with the rotar button pointing to the #1 plug. I also Putin another distributor but still nothing. So next I did an compression test with these results 1-4 at 125,80,125,150 and 5-8 115,135,120,135 I’m not sure where these numbers take me next. Any help would thankful.
Old Jan 1, 2023 | 08:14 PM
Conanski's Avatar
Conanski
Compression on #2 is low but it's not enough to prevent the motor from running, so start with the very basics..
- Do you have spark?
- Do you have fuel?
Old Jan 3, 2023 | 09:55 AM
BroncoG95's Avatar
BroncoG95
4wd Low
Check out the timing chain and gears it may have jumped due to wear and tear.
Old Jan 3, 2023 | 02:10 PM
xlt4wd90's Avatar
xlt4wd90
If the timing chain jumped, wouldn't that cause ALL the cylinders to read low?
Old Jan 3, 2023 | 08:51 PM
BroncoG95's Avatar
BroncoG95
4wd Low
I don't think so but I'm not 100% sure.
Dentside45690
Jul 15, 2022 08:05 AM
oscarguzzi
Jan 29, 2009 04:01 PM
sdpuff
Oct 13, 2007 05:24 PM
buckethead5k
16
Dec 29, 2006 09:45 AM
007bronco
Jan 9, 2005 10:59 PM
