Ford c6 460 trans issues
Old Dec 29, 2022 | 04:19 PM
hunter0128's Avatar
hunter0128
Trailering
Hello all I’m stumped lol and new to this. I have a 77 Ford with a 460 and c6 all mated up with atf. I know it’s got a vacuum module. I was Trying to test it to see if it would go into gear. It did not move except in reverse with a bunch of rpm. Now here’s my question. The c6 is new to me a.did I buy a bad c6. Or do I need to hook up vacuum and try again?
Old Dec 29, 2022 | 04:29 PM
85e150's Avatar
85e150
Moved to transmission forum.
Is this the transmission you swapped in, replacing the T18?
Old Dec 29, 2022 | 04:42 PM
hunter0128's Avatar
hunter0128
Trailering
yes it is. Finally had enough to bite the bullet on a c6. But got it used. Prior owner had it rebuilt by jasper. But I don’t know nearly as much about autos as manual’s.
Old Dec 29, 2022 | 05:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is it low on ATF? Is the internal filter in place?
The trans will engage in gear with or without vacuum attached. It won't upshift right, but it will go into gear.
sdmayhew
N. California Chapter
Jun 29, 2008 06:00 PM
intimidator7393
Nov 9, 2003 11:46 PM
bigric
Mar 20, 2003 05:49 AM
Andysutt
Jan 17, 2003 07:17 AM
BB
Jun 12, 2002 06:56 PM
