I pulled the PCM and not sure how to cross reference to a replacement. Mine says: E8TF-12A650-AS2B. I found one with the description: Remanufactured, No flash programming required. Plug and play application. OEM #E8TF-ASA, ASB, ASC.
Is this the correct replacement part? . Would this on e work?
Much appreciated! This is the last move to try to resolve my rough idle and stall issue. May be back for some ideas if this doesn't fix it. Merry Christmas Ford Truck family!
