ECC / PCM Replacement
Old Dec 22, 2022 | 01:19 PM
monkjim's Avatar
monkjim
2nd Gear
1988 Ford F250 4.9L / 300 2WD.
I pulled the PCM and not sure how to cross reference to a replacement. Mine says: E8TF-12A650-AS2B. I found one with the description: Remanufactured, No flash programming required. Plug and play application. OEM #E8TF-ASA, ASB, ASC.
Is this the correct replacement part?
. Would this on
e work?
Old Dec 22, 2022 | 04:28 PM
AuroraGirl's Avatar
AuroraGirl
this should be on valve cover
Old Dec 22, 2022 | 08:43 PM
torq'ta 5 8's Avatar
torq'ta 5 8
. Would this on
e work?
You didnt put in trans, but yes, it matches
Old Dec 22, 2022 | 09:02 PM
52splitsford's Avatar
52splitsford
4wd High
Flagship 1 has rebuild PCMS
Old Dec 22, 2022 | 09:28 PM
monkjim's Avatar
monkjim
2nd Gear
Much appreciated! This is the last move to try to resolve my rough idle and stall issue. May be back for some ideas if this doesn't fix it. Merry Christmas Ford Truck family!
Old Dec 22, 2022 | 09:35 PM
52splitsford
4wd High
no problem, My truck is currently shiftless for the holidays. cheers
sddaltongang
Sep 24, 2022 11:51 AM
bendfarmtruck
Aftermarket Products
Oct 2, 2021 02:22 PM
nicktomich1977
Escape & Escape Hybrid
Jan 15, 2011 12:40 PM
foxracer800
13
Feb 18, 2009 10:13 AM
whomrig
May 28, 2001 12:09 PM
