Electrical component ID
Old Dec 20, 2022 | 03:31 PM
casey_kreilein's Avatar
casey_kreilein
I posted about my 94 F150 project on another thread. But I already have my first question.
In the engine bay there is an electrical component that is missing. Attached is a photo of the location where it should be.
Any help is appreciated.
Old Dec 20, 2022 | 03:44 PM
Conanski's Avatar
Conanski
That would be the PCM... Powertrain Control Module.
Old Dec 20, 2022 | 06:00 PM
Scndsin's Avatar
Scndsin
Have something looks like this in a box or under the seat?
Old Dec 20, 2022 | 06:06 PM
Scndsin's Avatar
Scndsin
Might as well get this out of the way as well...
Can you post the calibration number from your truck?
Have a feeling it might be needed if you can't find above item.
Old Dec 20, 2022 | 06:21 PM
casey_kreilein
Here are the calibration and VIN stickers
Old Dec 20, 2022 | 09:47 PM
Conanski's Avatar
Conanski
Yeah that is it, I suggest you pull the cover off it and look for damage or corrosion. If that is original and it isn't damaged it is on it's last leg anyway.
Old Dec 21, 2022 | 06:13 AM
casey_kreilein
unfortunately that’s not mine. It was just the example of what someone showed me to look for in the truck. I didn’t have any luck finding one and have resigned myself to getting lucky at a loca junkyard for a temporary fix or just purchasing a remanufactured one.
Old Dec 21, 2022 | 08:48 AM
Scndsin's Avatar
Scndsin
Exactly so. I was hoping someone would step up & give you the engineering/ID numbers to find an identical match.
If not , all is not lost.
Old Dec 21, 2022 | 09:38 AM
torq'ta 5 8's Avatar
torq'ta 5 8
found this
Old Dec 21, 2022 | 12:38 PM
Scndsin's Avatar
Scndsin
Cardone 785755 at rockauto, not cheap without core. For 93 w/6 & E4OD.
Really strange with the build date of 7/94
Old Dec 28, 2022 | 04:46 PM
casey_kreilein
I ended up going to the dealership this afternoon and giving them the VIN. The tech gave me an engineering number of: F3PF-RA.
Looking on RockAuto the closest one I found was Cardone 789154 with F3PF-SA. The description matches the transmission and emissions standards.
I really just hate the uncertainty of this, especially since it is stemming from a likely stolen part.
Old Dec 29, 2022 | 08:37 AM
casey_kreilein
The search for the correct ECM continues. After my last post I started looking on Cardone’s website. Using the engineering number the dealership gave me I found this part number, Cardone 789041. Rock Auto has it but it isn’t listed as working for the 93 year models, which reinforces one of the earlier posts.
Old Dec 29, 2022 | 11:24 AM
Scndsin's Avatar
Scndsin
Sorry your having problems. I really hate to say it, but I'd trust the 785755 number over the dealership.
The member source (subford) of that info has been infallible when it comes to matching calibration # & the proper computer engineering #s.
yonu
Oct 3, 2021 11:04 AM
catalinaflyer
Jun 29, 2021 10:48 AM
avf100
Nov 12, 2019 05:56 AM
grandpa'sprideandjoy
West Virginia Chapter
18
Oct 12, 2010 06:49 AM
2004supacrewlariat
Feb 22, 2004 02:00 AM
