Just purchased a 2000 Excursion
Old Dec 20, 2022 | 02:55 PM
95Z28A4's Avatar
95Z28A4
Trailering
I just purchased a 2000 Excursion V10 Limited with 122K miles for my wife. It was a Texas truck and is in excellent condition.........maybe better than excellent condition. The previous owner asked a friend to address the sagging front leaf spring issue. Said friend installed a Zone Offroad 4" lift with Fox shocks. He also installed dual Fox steering dampeners. The lift has less than 1k miles on it.
I drove the Excursion 500 miles home yesterday and found the passenger side mirror has a blind spot. I almost changed lanes onto a Civic. I think the mirrors are tow mirrors, but they are kind of odd. The driver side mirror is close to the door, but the passenger side mirror is extended. I can't move either mirror in or out. Are they supposed to be fixed in position? Or they stuck in position? I've read several threads about upgrading to 08 tow mirrors for about $250. I don't mind spending the money if the 08 mirrors eliminate the blindspot. Again, this will be my wife's truck and I won't let her drive it with the blind spot. Opinions on the performance of 2000 mirrors versus the 2008 mirrors will be appreciated. I'm not concerned about appearances as both look OK to me.
I will be removing the lift and returning it to near normal height. My wife is 5' 2" tall. The lift measures 26" from the center of the axle to the front wheel arch cladding and 27" from the center of the axle to the rear wheel arch cladding. I've read several threads about using F250 Superduty springs. I called Junior at ATS. He suggests V code in front and C code in rear with stock Excursion tapered blocks. If I understand correctly, these springs should net no more than 1.5" lift over the stock Excursion springs. Can anyone confirm this?
The truck currently has 2019 F250 Superduty 18x8 six (double) spoke wheels with wheel spacers and 295/70/18 aggressive Cooper all terrain tires. The truck actually came with 2 spares - both spares on 18x8 six spoke wheels. I will be replacing these 34" Cooper all terrains with smaller 32" Michelin 275/65/18 LTX/AT2 all terrains. The Michelin LTX/AT2's have served me well on my 1998 Dodge diesel and our 2004 GMC Yukon. If I understand correctly, 2004 F250 King Ranch 18x8 wheels will fit my 2000 Expedition without wheel spacers. Has anyone used these wheels on their Excursion?
Thanks for the help!
Old Dec 20, 2022 | 03:09 PM
Theboneskes's Avatar
Theboneskes
You can upgrade tow mirrors for less than $140.00. I have these and work perfect!! Have had them on for more than 3 years without an issue.
https://www.ebay.com/itm/37257756407...mis&media=COPY
Where are you located? Id trade wheels possibly?
Old Dec 20, 2022 | 03:12 PM
95Z28A4's Avatar
95Z28A4
Trailering
Thanks for the link. I'm in Southern Louisiana. What type of wheels do you have?
Old Dec 20, 2022 | 04:30 PM
Kobra's Avatar
Kobra
Under the Excursion Tech Folder there is a lift measurement thread under "Suspension" that has a whole bunch of people's measurements before and after installing lifts.
Edit: Here's the link https://www.ford-trucks.com/forums/1...l#post14677330
If I remember correctly, most people who installed V/C codes had a measurement around 24-24.5" front and 25-25.5" rear.
V/C code along with 32-33" tires should drop you 2-3" it sounds like.
Kobra
Old Dec 20, 2022 | 08:12 PM
Misky6.0's Avatar
Misky6.0
Your pass side mirror is likely just stuck out. They tend to collect dirt in the channel and get stuck. A good wack should free it up. The '08+ tow mirrors are WAY better than the stock tow mirrors!
Old Dec 20, 2022 | 10:33 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
+1 to the 2008* tow mirrors, so much better than the little original pieces of crap
Old Dec 21, 2022 | 07:32 AM
CousinCarl's Avatar
CousinCarl
You understand correctly. Those 18" wheels Ford used on the KR and Lariats in 04 are rare to come by.
Old Dec 21, 2022 | 08:51 AM
WE3ZS's Avatar
WE3ZS
Welcome to the EX forum!
The ‘04 OEM 18”x8” series of wheels are the only OEM 16”+ wheels that fit our EXs properly without the need of spacers, they came in 4 flavors though, not just King Ranch, here’s a thread that shows all 4 versions. https://www.ford-trucks.com/forums/1...l#post16064812 I run the Lariat version on my wagon.
As was said above, your mirrors seem to be stuck, give them a persuasive shove to get them back in the game. My EX came with the tiny paddle mirrors and I replaced them with the period correct larger towing mirrors like you have then a few years later replaced those with a set of the ‘08 style towing mirrors. The ‘08 style (mine were from 1AAuto.com) are hands down the better option in my opinion, I tow a lot and those mirrors cover more area with less blind spots over the earlier options.
We need some pictures of of this excellent condition ‘00 EX, we love Pictures here!
Old Dec 22, 2022 | 12:30 PM
95Z28A4's Avatar
95Z28A4
Trailering
Thanks for the input. I've decided to go with the 08 mirrors. Is there any difference between the A1Auto mirrors and the less expensive eBay or Amazon mirrors for this application?
Old Dec 24, 2022 | 09:10 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
I went with the power folding mirrors from 1A Auto and they didn’t work, so instead of having me return them, they asked that I donate them to a local trade school.
For a few bucks more, I would go with 1A Auto and be reassured that my customer service will be up to par.
Just my thoughts.
Old Dec 25, 2022 | 07:33 AM
01__Excursion's Avatar
01__Excursion
This website always seems to have those spacer free rims avail.
https://www.originalwheels.com/ford-...0rims-2004.php
Old Dec 25, 2022 | 07:43 PM
95Z28A4's Avatar
95Z28A4
Trailering
WOW!! $2200 for a set of 4 not including center caps? I understand why the wheels are always available.
Old Dec 26, 2022 | 02:34 PM
John in OkieLand's Avatar
John in OkieLand
IF,
just plain ole Black Steel wheels are good enough for you,
I bought 8 of these,
4 for AT tires,
4 for Michelin street treads
Amazon Amazon
they look to be OEM, black steel wheels.
this is one time, Dorman is the only source I could find, after searching every where, salvage yards charge more than this, for used rims that show damage.
the auto parts stores won't even order these things, at least they wouldn't for me
Old Dec 26, 2022 | 05:27 PM
WE3ZS's Avatar
WE3ZS
Yeah, those ones are not cheap, but they do pop up sometimes on Craigslist or marketplace for much cheaper. I gave $600 for my Lariats with 50% rubber several years ago and paid $750 for a set Harleys with brand new Michelins for a friend here a few years ago. When they do pop up don’t delay, as they tend to not stick around long once available!
shanksyamaha
Dec 20, 2022 08:18 PM
perryg114
Dec 14, 2010 03:50 PM
rjbell
Nov 11, 2004 01:02 PM
rodsterman
Jan 2, 2004 01:13 AM
deere81
Nov 9, 2002 12:13 AM
