Need help
Old Jan 15, 2023 | 05:25 PM
  #31
Kwikkordead's Avatar
Kwikkordead
If you end up putting that HPO tube in and now it idles ok, I would be looking into buying another HPOP right away.
Old Jan 16, 2023 | 10:42 AM
  #32
bstarz65's Avatar
bstarz65
Originally Posted by Kwikkordead
This is the exact same thought that I had. Something wrong with the passenger side HPO feed, which incidentally is not monitored by the PCM. What I would suggest at this point is to obtain an HPO crossover line. There are a lot of products on the market for that application but the one that I have installed on my truck is solid stainless steel and it's formed in such a way as to absorb expansion and contraction of various parts of the engine as it goes through it's normal thermal cycles. It will yield to those minute changes in size and position for a very long time and not develop any leaks because of that. The one on this picture was put on my truck ten years ago or so, and no issues whatsoever. There are others who say they are a junk design, but bottom line, the right side HPO pressure is not monitored on the 7.3 design, and I disagree with that design. This balances the pressure between the two heads and then you can be assured that both sides receive the same amount of attention from the PCM.
Here's a link to the place that I bought it from.
https://shop.fullforcediesel.com/hpx...-dd-73l-hpx-sd
already have the crossover. just messed with the truck again and at idle I unplugged the injectors one at a time and the only diffrence was in no 7 and that one is spitting oil real good compared to the others.
Old Jan 16, 2023 | 10:43 AM
  #33
bstarz65's Avatar
bstarz65
Is it possible that #5 has a blown or failing Oring and Keping 1and 3 from firing
Old Jan 16, 2023 | 10:45 AM
  #34
bstarz65's Avatar
bstarz65
I guess I should put a gauge on the passenger side oil rail?
Old Jan 16, 2023 | 11:10 AM
  #35
bstarz65's Avatar
bstarz65
Any injector gurus out there that might have some InSite on this if a bad injector would cause 3 to be dead
Old Jan 16, 2023 | 01:30 PM
  #36
bstarz65's Avatar
bstarz65
GRASPIING AT STRAWS NOW COULD IT BE BAD FUEL.I took filter out to see if oil was on it and it was clear no green tint and smelled like turpentine
Old Jan 16, 2023 | 02:23 PM
  #37
Tpayne621's Avatar
Tpayne621
Don't make sense how that would only effect one side. But hey anything is possible. Quick way to check is get a 5 gallon jug put a couple gallons of fresh diesel in it. Then get a 5 foot long piece of hose and stick in it then clamp on back side of the fuel pump. The drain the bowl and get fresh fuel in everything and fire it up.
Old Jan 16, 2023 | 03:52 PM
  #38
Kwikkordead
IIRC the feeds from the HPOP to the cylinder heads are also separated from each other. If you have a badly bleeding o-ring in the passenger side head, that would give you the same symptoms that you have described. Raise the RPM, now the HPOP has enough volume to overcome that leak and the injectors start to fire. Don't know why they keep firing after you return the engine to idle. I guess an easy way to verify is to install a pressure gauge on that head and see what's up.
Old Jan 17, 2023 | 12:31 PM
  #39
bstarz65's Avatar
bstarz65
Back at it again, I have the frx so I took return line off head and put my finger over fitting and had wife turn on ignition and i was able to hold back fuel without much force is this ok or a sign of low fuel pressure even though my pillar gage says 64lbs
Old Jan 17, 2023 | 09:50 PM
  #40
Kwikkordead
Put a gauge on it. You can hold back a decent amount of pressure with just your thumb over a 1/4 inch hole.
Old Jan 18, 2023 | 10:17 AM
  #41
bstarz65's Avatar
bstarz65
I'm not understanding this no7 is firing 1 3 and 5 is not firing all are clicking from solenoid's but no oil from spouts on 3 5 7 so the wiring is good to those as well as 7 right? is it possible to have 3 injectors from full force about a year and a halve old to fail at the same time internally? my next step is to pull those injectors? and send them out to be tested? reeving it to 3000 not working to get it to smooth out now
Old Jan 18, 2023 | 11:31 AM
  #42
bstarz65's Avatar
bstarz65
Ok pulled the oil rail plugs under vc pulled front first not much oil came out pulled the rear and oil flowed pretty good out of that one is it normal for the front to have not much oil come out? still not convinced it's the injectors!
Old Jan 18, 2023 | 12:49 PM
  #43
bstarz65's Avatar
bstarz65
Well pulled the dead injectors and look what i found.
two busted Orings
  #44
Kwikkordead
That will do it!!
Old Jan 18, 2023 | 12:53 PM
  #45
bstarz65's Avatar
bstarz65
Any advice on putting this back together should I pull all 8 and replace Orings or just let it ride.
