Replacement steps for 5th wheel
Old Dec 17, 2022 | 04:32 PM
Je942010's Avatar
Je942010
Looking for some suggestions for a replacement set of steps for my 5th wheel. I’m currently using a set of LCI Alumi-tread steps on it but I’m having issues when we get on campsites that aren’t level and the drop from the bottom step to the ground is to much. I’m using an aluminum single step to make up the distance but I’ve had it slip out a few times on our dogs and kids and now the dogs are reluctant to go down them due to having the platform flip from under them on multiple occasions. I’m looking for a set that will go all the way to the ground but don’t want to have to deal with flipping it inside the door when we travel. Primarily looking for one that will go under the door in the existing space where the pullout set goes. Preferably aluminum due to camping near the ocean and living in NY so dealing with salt is an issue year round. Looking to replace both sets so I can let the dogs out of the garage and main door and they hopefully don’t remember the issues from the last few seasons. Here’s a pic of what I have to do now with the platform when the sites are unlevel. You can see the drop off from the stone pad to the grass and how far the front and rear steps are off the ground.
Old Dec 17, 2022 | 05:06 PM
Back2Gas?'s Avatar
Back2Gas?
Same company makes a 4 step version of your 3 step that I will probably get since I wiped mine out recently. Only issue is that it is 1/2" wider where they mount.
I think they will fit on the lowest set of 4 holes with some slight bending of the 'out riggers'. If I try to get them further up I think a weld may break.
Old Dec 17, 2022 | 06:50 PM
senix's Avatar
senix
well here is what I have, a direct replacment that fits in place and does not go inside the unit.
adjustable feet.
Old Dec 17, 2022 | 09:17 PM
tweettweet's Avatar
tweettweet
I got the glow steps like sinex showed. I find them very versitil with thier accordian action , 3 adjustment hight at top and bottom leg adjustments.
Old Dec 18, 2022 | 06:21 AM
senix's Avatar
senix
Glow steps are light enough the misses can operate it too.
I did go to lowes and buy some thread anti skid strips to put on them though.
Old Dec 18, 2022 | 08:11 AM
Je942010's Avatar
Je942010
Is there any flex in these or are they solid once deployed and the legs are down?
Old Dec 18, 2022 | 08:21 AM
tweettweet's Avatar
tweettweet
I find them solid. And im no ight weigjt There are vidios on them. Wish u cpuld find some to phyically test ur self. By the time i bought mine b flation hit and like every thing i think saty. Good luck.
Old Dec 18, 2022 | 08:31 AM
senix's Avatar
senix
Very solid to me.
Here is a pic of the tread I added for traction
Old Dec 18, 2022 | 09:28 AM
HRTKD's Avatar
HRTKD
+1 to the Torklift Glowsteps. I've had mine for a few years now and they're great. I'm rarely in a campground so an uneven camping spot is normal. These steps take care of that.
Old Dec 18, 2022 | 09:35 AM
acadianbob's Avatar
acadianbob
Love our TorkLift Uprising steps. Ours do go inside but they are much more versatile to use. You might find that it would work well for you as we rarely have to fiddle with the step adjustment. They are very solid and well made.
https://www.ford-trucks.com/forums/1...g-install.html
Old Dec 18, 2022 | 11:13 AM
traveldawg's Avatar
traveldawg
We have the Glowsteps too. Love them. I put some non-slip sandpaper-like self adhesive strips on the front part of the steps but have since covered 4 of the steps with these treads.
Since we had the MorRyde IS put on the rig got raised a bit so we added one more step - pretty easy to do.
Also consider this
Old Dec 18, 2022 | 08:17 PM
KU4OJ's Avatar
KU4OJ
I saw a fellow who had made a wooden box and used that for a step. Inside the box were all the muddy shoes that weren't allowed into the camper.
Old Dec 19, 2022 | 08:09 AM
Je942010's Avatar
Je942010
How much adjustability is there for the height on the glow steps? Here is a pic from another site when we’re in Myrtle and you can see that on a concrete site I’m about 9” to the ground from the bottom step on the front and about 12” on rear door. The 5th wheel is a 43’ triple axle with hydraulic leveling so I normally run auto level and keep it there unless the steps are way up in the air. Hoping that the next set of steps I buy will be the last steps I put on this. I replaced the original steps with these 2 years ago and wish I had gone another route to be honest. The original set had holes in them and I was worried about the dogs nails going in the hole when they were getting in and out which is why I bought the aluminum set due to them being solid.
Old Dec 19, 2022 | 08:59 AM
HRTKD's Avatar
HRTKD
The feet have about 4" of adjustment, then the entire set of steps has about the same amount, meaning that the point where the steps pivot at the top has three settings that allows you to make the steps higher or lower.
Old Dec 19, 2022 | 03:52 PM
traveldawg's Avatar
traveldawg
There are really good measurements of the rise and run of the steps on TorkLift's web site for these stairs. You can see the various models, the width, adjustability, videos, etc. You can even enter your rigs model and (sometimes) it will tell you which model of steps you need.
And when you mount them you can even position them where you want on the mounting points or just use the existing holes as I did.
