Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Vin Help Please
Old Dec 15, 2022 | 08:25 PM
Kintore's Avatar
Kintore
1st Gear
Vin Help Please
Every decoder I've tried, including the one on this site, tells me this Vin doesn't exist. Am I seeing it wrong? F70DUD71711 Can someone decode it for me? Thanks in advance.
Old Dec 16, 2022 | 12:37 AM
85e150's Avatar
85e150
Tomorrow morning.......
Old Dec 16, 2022 | 02:26 PM
85e150's Avatar
85e150
OK so I'm late...
F70 = F700
D = 330 2V HD FT gas V8
U = Louisville Assembly Plant
D71711 = 1968 numerical series, August 1968 production
156 = 156 inch wheelbase
J = Red
F703 = F700 gas, 24,000 lbs GVWR
481 = Black ladder and crush vinyl, standard cab
9 = New Process model 541 five speed direct transmission
E3D
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 ratios / 17,500 lbs. Rear Axle Capacity.
D = Ford-Rockwell/Timken 7,000 lbs. Capacity Front Axle.
24000 = 24,000 lbs. Gross Vehicle Weight Rating.
164 3800 = 164 certified net HP @ 3800 RPM
A18481
A1 = Ford of Canada Central
8481 = Special Order Number
The front axle code is an optional axle--only optional axles were listed from '64 to '69. Anything else special is not indicated--the usual items like paint & drive train are all indicated.
Bronco 79
Large Truck
Aug 2, 2022 07:03 PM
Woodchuck82
Large Truck
Mar 20, 2022 05:20 PM
55 dude
May 13, 2021 09:42 AM
NewFordOwner234
Large Truck
Apr 20, 2021 07:04 AM
gangstakr
Aug 20, 2020 11:32 AM
