Hubs
Old Dec 12, 2022 | 10:10 PM
ttaanneer's Avatar
ttaanneer
4wd Low
Hubs
Hey guys I have a 97 f250 7.3. My problem is my right side hub locks in and when I spin the tire the drive shaft and the other tire will turn but when I lock the drivers side the drive shaft dose not spin or the right wheel. I took the hub apart and it seems to be working. When I manually push the hub In it ingauges the axel and the axel spins with the tire but the drive shaft doesn't move or the other tire. Any ideas? Is my hub broke or somthing worse?
Old Dec 13, 2022 | 08:39 AM
knottyrope's Avatar
knottyrope
Pull the axle shaft and see if it's broken inside the tube.
Old Dec 13, 2022 | 10:06 AM
ttaanneer's Avatar
ttaanneer
4wd Low
Ok thanks I'll try that
Old Dec 13, 2022 | 11:24 AM
helifixer's Avatar
helifixer
I was working on a truck last week with the same issue, Warren hubs, the passenger side would not lock. took it apart and the inner part that moves in and out when the **** is turned was stripped so it never moved in to engage the hub.
Old Dec 13, 2022 | 11:48 AM
ttaanneer's Avatar
ttaanneer
4wd Low
Ya I took it apart and it looks grate and moves properly. I am going to try to see if the axle is broken.
Old Dec 13, 2022 | 12:38 PM
knottyrope's Avatar
knottyrope
if you never removed the spindle, get a 10lb slide hammer and use the 3 jaw locked on the spindle tube nuts
mine took 200 wacks with a 5 lb to get it off
tryon.nico
Dec 13, 2022 01:06 PM
Nabors
Oct 7, 2012 10:19 AM
cinebar2
Dec 30, 2009 10:00 PM
TRAINHORNMAN
21
Dec 5, 2009 09:35 AM
Sf006
Bronco II
Jun 8, 2004 05:33 PM
