I have an 03 EB and just put it in the ashtray spot. Just pull out the ashtray like you would to dump it and in it's place goes the unit. I don't use the ashtray for anything else. When I'm done, I unplug and put it away until needed again. I'll take a pictue later today if you would like to see how it looks
Mine is mounted under the dash, just right of the steering column. Have not had any problem with knee clearing it and it has worked just fine. Another option you could consider is mounting on top of the dash. I personally don't like it up there but some people do. It can be setup to come on just ahead of the vehicle brakes and that keeps things in line really well. I have a hensley hitch and that is an important issue. Once set up properly, you ought not to ever have to manually operate it unless you have an emergency or just want to check things out before pulling away for the first time.
