Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1965 C600 Decode
Old Dec 11, 2022 | 08:21 PM
Crazzysuperbike's Avatar
Crazzysuperbike
4th Gear
1965 C600 Decode
Originally Posted by 85e150
Greetings and welcome to FTE!
Find your data plate--on the driver door below the latch, possibly the glove box, possibly the door jamb--not sure of the location for your vehicle.
From that, post the codes, especially the axle codes. The axle code gives the clue to the brakes.
Just got this 65 c600 can anyone give me any more info and decode this for me?
Old Dec 11, 2022 | 11:28 PM
85e150's Avatar
85e150
Welcome to FTE!
A full decode deserves it's own thread so I've made you one.
C60 = C600 gas
M = 330 2V HD FT gas V8
U = Louisville Assembly Plant
686660 = 1965 numerical series, May 1965 production
099 = 99 inch wheelbase
- = Should be color code, possibly a typo
C600 = C600 gas, 20,000 lbs GVWR
191A = 1 = Light Gray Crush Vinyl & Light Gray Block Weave Vinyl / 91A Standard Cab
A = New Process model 435 four speed transmission
62 = Rockwell(Timken) model F-106 single speed rear axle, 6.20 ratio, 15,000 lbs capacity
No front axle code. In '64-'69 only optional axles were listed. Thus, you have a Ford standard axle, probably 5,000 lbs capacity without power steering
20000 = 20,000 lbs GVWR
160 3800 = 160 certified net HP @ 3800 RPM
33 = Detroit District Sales Office. No special order number so the truck was probably "bought off the lot" from dealer inventory.
Old Dec 18, 2022 | 07:25 PM
Crazzysuperbike
4th Gear
Much thanks!
Hey thanks so much for the decode! Helped alot! Only problem I'm having now is trying to find a brake master cylinder for it. All the ones on Napa md/hd for '65 do not look like what is on the truck.
Fe23455 made in usa
Old Dec 18, 2022 | 08:15 PM
85e150's Avatar
85e150
A recent post from a fellow C series owner. Lots of stuff remained the same throughout the C series production. Brake and clutch masters--maybe, as they are the goofy vertical units. Links and illustrations, you'll have to read through it:
https://www.ford-trucks.com/forums/1...l#post20615280
Illustration of brake system:
https://www.ford-trucks.com/forums/1...l#post15855346
Tricks to dealing with the MC:
https://www.ford-trucks.com/forums/1...l#post15451775
Off topic but here's the clutch for your era:
https://www.ford-trucks.com/forums/1...rake-boot.html
Sofkee
Large Truck
Jun 11, 2022 02:49 PM
mreams
Large Truck
May 20, 2022 08:10 AM
noal133
Large Truck
Jul 27, 2021 03:29 AM
cousinscustoms
Large Truck
Jul 1, 2021 11:28 PM
Ridehard1333
Large Truck
Apr 19, 2021 11:33 PM
