Torque Converter Lock Up Sequence
Old Dec 11, 2022 | 01:06 PM
posmtrhm's Avatar
posmtrhm
Can anyone explane how the torque converter lock up sequence goes? My Motorhome is a E450 it will not shift into overdrive unless speed is over like 35-40 mph. Will lock up happen as soon as trans shifts into Overdrive? If So is it supposed to unlock with a slight throttle application? What triggers the converted to unlock?
Old Dec 11, 2022 | 06:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The converter can lock in any of the forward gears if the conditions are right.
In first and second gears it can only lock if the accelerator is more than 75% of the way to the floor. In third and fourth it can lock at very low throttle openings. It can unlock when the throttle is pushed, if the speed drops, or if you let off the accelerator. The PCM (Powertrain Control Module - the computer) makes all of these decisions.
Most of the time the shift sequence is 1-2-3-converter lock-4.
18CCLBKR
Dec 4, 2018 12:11 AM
mackdog
1983 - 2012 Ranger & B-Series
Jul 14, 2011 12:34 AM
SDF250fan
Jul 26, 2010 07:07 PM
hytekredneck
May 26, 2008 09:14 PM
