interior paint decode
Old Dec 11, 2022 | 09:49 AM
ahdmeyer's Avatar
ahdmeyer
new to me 1951 ford f3 does f3h18c228** does the vin show the paint code ? i want to paint the interior door jams before i put the new weather stripping on it is red and have searched and found out it may be vermillion or coral flame red . also if it is do you know if it is the same as the red on the 9n tractors of the 50 era thanks any help is appreciated. sure i will have many more questions.
thanks
al
Old Dec 11, 2022 | 12:51 PM
mtflat's Avatar
mtflat
Welcome to FTE!
The code you posted looks like a blend of serial number and assembly code
Is this from the firewall near the cowl or frame rail? Only the firewall stamping can tell you the body color IF it is there.
Interior was painted the same color as the exterior.
Red on trucks in 51 would have been Vermillion
Without knowing for sure, I doubt it is the same as tractor/implement paint from the same era. Like trucks, most tractors from that era have been repainted.
Tim
Old Dec 12, 2022 | 02:21 PM
52 Merc's Avatar
52 Merc
Your vin does not include the paint code. For '51, it will identify the series, engine, year and assembly plant. It should be located on the right side frame rail near the motor mount. The firewall stamping is not the vin, but the production code. Sometimes it shows the series, depending on the plant. Typically it lists the assembly plant, color code and assembly date. If you can post a picture of the firewall stamp, we can decode it better for you. Sometimes the stampings are light or partially done and can be easily confused with the wrong letter/number.
Old Dec 12, 2022 | 03:22 PM
51fred's Avatar
51fred
My 51 is a late build and has a plate on the glovebox door. (Another place to look) You can see the color code for mine below.
Old Dec 12, 2022 | 03:44 PM
abe's Avatar
abe
So you're telling me that 52's have the data plate on the glove box door?
Old Dec 12, 2022 | 03:47 PM
51fred's Avatar
51fred
I believe so.
Old Dec 12, 2022 | 04:07 PM
52 Merc's Avatar
52 Merc
As of September, '51, Ford replaced the cowl stampings and firewall patent plate with the data plate in the glove box that we're all familiar with.
Rich, not sure if we've decoded your production code before, but you have a 21 November, '51 scheduled build date.
Old Dec 12, 2022 | 06:39 PM
51fred's Avatar
51fred
We did, but I I wasn't sure. I knew it was 21L. I think it was "I" that didn't get used, right? A=Jan, etc.
Old Dec 12, 2022 | 10:16 PM
mtflat's Avatar
mtflat
That is correct.
cheddar89
Mar 15, 2012 06:03 AM
plowhand
Nov 12, 2005 04:47 PM
wizzard351
Jun 10, 2005 04:04 PM
justmeandshe
May 29, 2004 12:23 PM
