Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
76 C700 Shifting issue
Old Dec 10, 2022 | 09:27 AM
Topsykidd23's Avatar
Topsykidd23
8th Gear
Slave cylinder was leaking, ran it dry on the road. Jammed it into 3rd 1 time. could get it back into second after having to kill it at a light. Got it home putting in 2nd. Now that I've replaced the slave cylinder and bled the system I've come to realize it is stuck in gear, I assume 3rd.
I can get the truck started by holding the clutch down so I'm assuming that my clutch is fine. However, I cannot get it into neutral and when I put it into reverse it just dies.
Truck has a 360 motor not sure what kind of trans but I do know its a manual 5 spd with High Low.
Ive read a few posts about the shift rails possibly being jammed and heard that sometimes the 2 spd can hang up when trying to shift in and out of gears.
Today I will be pulling the top of the trans off in an Attempt to check the shift rails.
I honestly have very little experience with transmissions and worry I wont be able to identify the issue even if its staring me in my face.
If anyone one has any insight on this please post.
Old Dec 10, 2022 | 11:43 AM
85e150's Avatar
85e150
The 2 speed hi/lo is in the rear axle, so that's not the problem.
Be careful pulling the top off the transmission. You will want to place it and the linkage in neutral when you reassemble it.
inspect the forks and everything related. Post pictures if something doesn't look right.
Old Dec 10, 2022 | 03:09 PM
Topsykidd23
8th Gear
I was able to take the top of the trans off and found a couple of issues right off the bat.
The truck was definitely stuck in a forward gear. the middle plate that the forks are supposed to grab was stuck to one of the gears. I was able to move it back off the gear and it is free now. I am hoping this puts my trans back into TRUE neutral.
As for the shift forks... well you can look at the pictures... Do you know where I could get replacements?
I am now in the process of draining the gear oil in hopes of retrieving the broken fork and pads...
Old Dec 11, 2022 | 05:07 PM
Topsykidd23
8th Gear
BUMP? Please Help
Old Dec 11, 2022 | 07:31 PM
85e150's Avatar
85e150
What is the transmission code on your warranty plate?
I'm betting this is a NP 542.
Decent pic here:
https://truckpartsinventory.com/parts/details/81557298
https://truckpartsinventory.com/tran...ture-542-parts
He's got a picture but limited parts.
Another one--you can search by np 542 parts and find more:
https://www.qualitygear.com/lightdut...nsmissions.php
jackdichiara_03
22
Mar 8, 2022 11:30 PM
jerrylynnb
1983 - 2012 Ranger & B-Series
25
Mar 10, 2012 03:50 AM
85GT5.0
Jul 15, 2009 08:13 PM
zach_barrow
Feb 4, 2008 09:10 PM
radar_ridr
Mar 2, 2003 01:44 PM
