Wrecked 400?
Old Dec 7, 2022 | 01:22 AM
El_Burrito_Bandito's Avatar
El_Burrito_Bandito
Wrecked 400?
I've come across a 400 motor for pretty cheap, but the guy said it came out of a wrecked car and it looks like the pulley is bent from where it hit something. What are the chances that the crank is bad? I can spin the crank by hand, so that's a good sign right? Even if the block is trashed or something else is wrong, i really only want the crank and pistons.
Old Dec 7, 2022 | 06:07 AM
DaveMcLain's Avatar
DaveMcLain
It is possible to destroy the engine in a wreck but it is also very easy for the pulley to get bent up either from a collision or more likely from man handling the engine during removal at the salvage yard. Have you ever seen the removal technique where using a wrecker the front of the car is lifted off of the ground by the engine and then a torch is used to cut everything until the car falls off of the engine? This method of removal can sometimes damage sensitive components.
Old Dec 8, 2022 | 11:37 AM
mark a.'s Avatar
mark a.
When in doubt find a shop that can check it for cracks. A good hit could fracture it.
Old Dec 12, 2022 | 11:34 PM
El_Burrito_Bandito
Thanks guys, im gonna go ahead and pick it up tomorrow, tear it down and hope for the best. If anything, i could break even on the heads and other parts.
lizardman1
Oct 4, 2021 05:43 PM
Gary Lewis
Feb 22, 2017 04:08 PM
69Mach1scj
Nov 28, 2012 05:24 PM
78MeanGreenBronco
24
Nov 23, 2008 06:28 AM
ClatonK
Jun 20, 2005 11:57 PM
