Solenoids
Old Dec 4, 2022 | 03:39 PM
Squid8392's Avatar
Squid8392
Solenoids
If any of my OEM solenoids are bad, eg. EGR solenoid, diverter Solenoid, could I use a Pneumatic valve Solenoid from Amazon? Link below
Amazon Amazon
Old Dec 4, 2022 | 04:43 PM
FuzzFace2's Avatar
FuzzFace2
I dont see why not as long as the old one it replaced was NC valve like that one.
I dont know if the Ford valves are NC (normally closed) like that one or NO (normally open) as that could make them not work when they are meant to.
How did you test the old ones to see if they are bad?
Dave ----
Old Dec 4, 2022 | 04:53 PM
Franklin2's Avatar
Franklin2
Nope. A lot of the valves under the hood are 3-way. In other words, if you open the valve electrically to apply vacuum to open the EGR valve, and then close the valve to shut the vacuum off, where is the vacuum that was in the EGR valve going to go? The ordinary valve you linked to shuts off completely, so the EGR valve stays open even when the electrical valve is shutting off the vacuum. Many miles down the road it might eventually bleed off.
Most factory EGR electrical valves were 3-way, when you shut the vacuum off, it opens a port with a foam filter to the EGR line, letting the valve relax and shut.
Another problem you will run into, some valves are piloted valves. They use the air pressure coming in to actuate the valve spool. These will have a minimum air pressure they need to work.
Old Dec 4, 2022 | 06:33 PM
Squid8392's Avatar
Squid8392
would this valve work?
Amazon Amazon
Old Dec 4, 2022 | 07:22 PM
FuzzFace2's Avatar
FuzzFace2
Thank you Dave as I dont have any of them things under my hood.
Dave ----
Old Dec 4, 2022 | 08:06 PM
Franklin2's Avatar
Franklin2
Originally Posted by Squid8392
I believe it might actually. Put the EGR valve on port 2. I believe the 1st window in the diagram is the valve position with no power, so port 3 would stay open, port 1 would be the vacuum source. You will have to try it to make sure. It is 12v and it's good for vacuum, so it might work.
irishguyincc
1983 - 2012 Ranger & B-Series
Oct 23, 2005 10:44 PM
cougar_1987
Oct 20, 2004 10:11 PM
m1
May 12, 2003 12:22 AM
mweeps
1978 - 1996 Big Bronco
Mar 5, 2003 10:18 PM
sandrat
Feb 26, 2003 03:43 PM
