I beam pivot bushing question
Old Dec 4, 2022 | 08:43 AM
z31freakify's Avatar
z31freakify
I'm replacing the I beam bushings, I've done them many times before but I have always pressed them in all the way in, and from factory they have like a 1/4" gap.
So is pressing them all the way in the wrong way? Or doesn't matter?
And here you can see how they look when they are pressed all the way in and looks as if it might mess with toe and caster
Old Dec 4, 2022 | 01:18 PM
FinnishStroker's Avatar
FinnishStroker
I have done them few times,recall pressing them all the way in.
Can't help about it being good or bad thing.
I have always done alignment after those bushing.
I recommend Energy Suspensions polyurethane ones.
You need to buy cheap regular ones to get the outer shell from them,If going with those polyurethane ones.
OEM types are pretty much shot after putting them in.
Old Dec 4, 2022 | 05:43 PM
Hit Man X's Avatar
Hit Man X
30000 miles on Energy in 96. So far, still okay and left OE shell installed. Can measure if needed.
Old Dec 4, 2022 | 06:27 PM
z31freakify
Decided to leave the gap like the factory did, test drove truck drives better, grounded off some meat off the I beam to clear the upper ball joint now I can mess with camber and caster. Also didn't have enough time to do driver side I beam bushings, but did ball joints.
rgnprof
Jun 24, 2021 04:27 AM
Mike1376
Mar 3, 2018 07:59 PM
timbersteel
Feb 22, 2016 08:57 AM
jaroh
Jun 6, 2013 10:11 PM
JonathanN
Apr 3, 2012 02:40 PM
