Camber/caster bushing replacement
Old Mar 3, 2018 | 12:08 AM
Mike1376's Avatar
Mike1376
On my 1984 F150 4x2, I ordered Moog bushings for camber/caster. I got the 2.5* adjustment bushings since my camber is out a LOT just at a glance.
It’s a POSITIVE camber but when I back up for 2’ or more, the wheels pivot and suddenly I have equal NEGATIVE camber.
Anyways. Today I went to install them to no avail as I only got to the passenger side with 0 success.
The old bushing was removed with with relative ease but the new bushing would not sink all the way into the hole. I pounded on ball joint areas but I was just beating the $h___ out of the new bushing with zero movement. This continued until I removed the wheel/spindle(?) assy where after that I was able to put it on my work bench and use the BFH to full affect.
Upon reinstalling the wheel assembly, I couldn’t get both ball joint’s cone bolts to settle in. I tried all sorts of methods. I managed to get the lower ball joint nut up about 1/8”.... upon looking up I realized it was my new bushing was causing the resistance. The new bushing was being pushed back out the more I was able to get the bottom nut tightened.
Anyway. So, bushing isn’t even all the way in, so obviously no adjustments have been made. That but as well as the bottom bal joint nut stent even tightened all the way.
I don’t want to take it to a shop.
any help please? What am I doing wrong?
THANK YOU!
Old Mar 3, 2018 | 03:18 AM
Rembrant's Avatar
Rembrant
I just went through all this on my 1984 F150 4x2 a few months ago. I replaced everything in the front end, and used all Moog parts as well.
I'm guessing this that there is a ridge of rust built up on the ball joint, and in the hole in the knuckle (length ways, matching the slot in the alignment bushings). I noticed this on my own truck as well, but since I was doing it all on the bench, and installing new ball joints, it wasn't a problem. If I recall correctly, I used a Dremel to remove the ridge in the hole in the knuckle. If you're trying to install new bushings, and the slot is in a different location, the new bushing will be fighting against a ridge of rust on both the ball joint, and in the hole. Once I had that little ridge smoothed out, the bushings slid in the holes with ease.
I'm just guessing. I could be way off base. Like anything, it's hard to know without seeing it. Maybe there's an issue with the new bushings.
Regarding the camber issues. Mine looked like it was bad on the passenger side, and I was sure I was going to need alignment bushings. After I replaced all of the wear items in the front end, I re-installed my factory 0-degree bushings, and all that was required for alignment was a slight toe adjustment. Camber was well within spec.
Just my 2 cents worth.
Old Mar 3, 2018 | 07:12 AM
Franklin2's Avatar
Franklin2
There are certain things that need to be done to vehicles that require special tools to accomplish, this is one of them. You will need to take it to a alignment shop to get the alignment in spec for it to drive correctly and have good tire wear. While you can buy the bushings and install them yourself, you have no way of knowing if you bought the right one and you have no way to set it correctly. Besides the camber, the bushing also adjusts the caster.
While you won't find a bigger cheapskate than me, and I always try to do everything myself, this is one area where you really can't do it without a shop with the equipment.
Old Mar 3, 2018 | 09:10 AM
FuzzFace2's Avatar
FuzzFace2
THANK YOU!
With what you said above I would say bushing will not fix this as it should not change moving forward and back so you have warn out parts someplace.
Dave ----
Old Mar 3, 2018 | 02:11 PM
Mike1376's Avatar
Mike1376
yeah, you’re right there was ridges left from the old bushing. I just looked at it. I didn’t check for that before. It’s still not going in all the way and staying in.... I’m not sure why?
i have a lot coming up with work so I am going to take it to a garage and have them replace upper/lower ball joints, radius arm bushings and I beam axle bushings....
im going to change out both tie rods and pitman arm myself but not now.
I wanted to replace the bushings for camber and caster but also because both of them are damaged. Looks like someone tried to turn them and the “bolt head” of the bushing collapsed...
and yeah, I’ve done the tape measure alignment before and it was better than nothing but my alignment was still out and my tires still got chewed up!
Old Mar 3, 2018 | 02:13 PM
Mike1376's Avatar
Mike1376
Dave ----
i definitely do. I think the entire front end needs to be gone through. I was going to put a 2” lift (spacers) on it but not until I know everything with my front end and steering is 110%
Old Mar 3, 2018 | 06:59 PM
Franklin2's Avatar
Franklin2
2 inch spacers will cause more problems. You cannot lift these trucks without messing up the alignment, and the guy at the shop can't get it back in, even with the most radical bushing. Usually they can barely get it back in alignment with a 1.5 inch lift above stock. Beyond that, you need a lift kit with the brackets.
Old Mar 3, 2018 | 07:59 PM
Mike1376's Avatar
Mike1376
yeah I hear ya. My good friend had one and just did 2” suspension lift on it and it was never perfectly aligned but it wasn’t bad. It was within acceptable standards (per Firestone) and I know it tracked strait and didn’t chew tires up bad. He did “forward cross” rotate his tires twice a year which is usually twice the amount that is recommended based off of average mileage per year.
Different ballgame but I have a Jeep Grand Cherokee that I put a 2.5” kit on it (spacers) and my alignment is actually perfect
crawlin-kingsnake
Feb 19, 2018 03:53 AM
TylerF100
Sep 10, 2016 03:34 PM
timbersteel
Feb 22, 2016 08:57 AM
wick246
Apr 16, 2004 05:23 PM
carriljc
1978 - 1996 Big Bronco
Oct 27, 2003 03:17 AM
