Sponsored by: Real Truck
Intermitent Vent Control Issue
Old Dec 1, 2022 | 09:31 AM
EzPc's Avatar
EzPc
Question Intermitent Vent Control Issue
Good morning all,
Search has not come up with not exactly what I am looking for. My2002 F250 SD vent control **** seems to be working slowly / intermittently when changing the vents. Regardless of which setting I choose the defrost is always blowing and the floor will not blow at all. I can get windshield only, windshield + Vents but not Vents + floor or Floor only and that is only part of the time. When I switch the selector I can hear the "doors" in the dash move open or closed but sometimes its slow or does not work at all. I have read about the pump in the engine area and the solenoid that actuates the 4x4 system which works. I also have control over the temperature so the bleed door control seems to be fine. And the Fan speed works as well. I am thinking the actual control switch in the array where the vacuum hoses connect may be the culprit bbut thought I would consult you folks here to see if anyone has had this issue. thanks in advance for your time and assistance.
Old Dec 1, 2022 | 09:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
You have a vacuum leak somewhere. When there is insufficient vacuum the heating system defaults to defroster mode.
I am not going to say it is the ESOF system. That is a possible area for vacuum leaks, but there are many.
Old Dec 1, 2022 | 10:18 AM
EzPc's Avatar
EzPc
Thank you for your insight... could the leak be the control **** itself? Anyplace I can go to see a schematic of this system components ?
Old Dec 1, 2022 | 10:46 AM
redford's Avatar
redford
The leak could be anywhere. Your truck is over 20 years old. Rubber deteriorates. Seals crumble. Don't get fixated on one part or system.
My method of finding a vacuum leak scares some people, but it works for me.
Start your engine. Take a propane torch, open the valve but don't light it. Pass the torch opening over every hose, valve, fitting and gasket mating surface. If you hear a change in the idle you have probably found your leak.
Some also use carb cleaner for the same purpose.
Old Dec 1, 2022 | 10:51 AM
EzPc's Avatar
EzPc
Hum... I can see where it I were looing for an engine vacuume leak how this works great... but I don't see how this will work on the AC/HVAC system....
Old Dec 1, 2022 | 11:00 AM
redford's Avatar
redford
I should specify that this is for gas engines. The engine vacuum is the source for truck vacuum.
A Power Stroke will have a vacuum pump. That considerably changes the troubleshooting methods used.
Old Dec 1, 2022 | 11:10 AM
EzPc's Avatar
EzPc
Well that makes more sense... so there is no vacuum pump on a Gas powered power stroke?? Have to buy a new propane tank then...
Old Dec 1, 2022 | 11:11 AM
projectSHO89's Avatar
projectSHO89
There's no such thing as a "Gas powered power stroke". "Power Stroke" was the marketing name for the diesel power plant. A separate vacuum pump is required for diesels (as well as the newer Eco-boost engines).
This does not sound like a supply vacuum leak issue. If it was, ALL outlet airflow would default to the defrost ONLY. <<-- THIS IS A CRITICAL OBSERVATION! Most likely, it's an issue with with the one specific vacuum-operated mode door that is malfunctioning.
Sounds like it's an issue with the panel-floor door is stuck in the "panel" position which blocks off most airflow to the floor outlets. This could be due to a fault in the vacuum portion of the mode switch, an open vacuum line, a failed vacuum motor or its linkage, or a damaged/jammed door inside the plenum.
Look for the vacuum motor with the blue and yellow vacuum lines. IIRC, it's behind the glove box on the SD trucks. Make sure that they're both connected and the linkage to the mode door bell crank is intact. Switch the mode to FLOOR and see if both lines have vacuum (vacuum supply enabled, of course). If vacuum is lost to both, that mode door motor defaults to the panel and defrost outlets only.
Old Dec 1, 2022 | 11:13 AM
redford's Avatar
redford
I never say never. Once you start looking at the chassis cab rigs you never really know what you'll see.
Old Dec 1, 2022 | 11:36 AM
EzPc's Avatar
EzPc
Anyone know of any resource schematics that show the system for troubleshooting? Or I guess I will just have to pull the radio and check each vacuum line.... I did pick up a replacment vacuum select switch... [not sure the office name] and may just try to switch that out...
Old Dec 1, 2022 | 11:53 AM
projectSHO89
Leave the radio alone.
Empty out the glove box (or just dump everything on the floor when you drop the door all the way open). Squeeze the ends to allow full motion and flip the door down to access area behind there.
Old Dec 1, 2022 | 12:47 PM
EzPc's Avatar
EzPc
Ok thank you for the suggestion... however I have to install the reverse camera and might do it while looking to fix this.. but I will try without taking the radio out just to get the experiance.
Allstar recovory
Oct 23, 2013 11:55 AM
librty02
2004 - 2008 F150
May 12, 2011 10:04 PM
dwe3243
1997 - 2003 F150
Apr 23, 2010 08:10 PM
snoman
1978 - 1996 Big Bronco
Apr 19, 2006 09:30 AM
